Hey guys, I think our prefixes are under utilized and I wanted to make a quick post that sort of shows how great they are. To filter the threads you see by prefix, scroll down to the bottom of the forum to where you see this: From there, you can select any topic you wish from the pull down to filter the forum. For example, If I wanted to see only threads pertaining to tech, I would chose the "Technical" prefix and then click "Show Threads." The H.A.M.B. will then display only technical threads. If you do this from the main HAMB forum, you will see tech threads from every forum, including the period correct forums. If you do this from the "Traditional Hot Rod" forum, you will see tech threads only on Traditional Hot Rods. Prefixes kind of rule... And people need to use them when viewing more often.
