1952-59 Ford How to wire a tach?
Discussion in 'Off Topic Hot Rods & Customs' started by 53Flathead, Apr 7, 2014.
  1. 53Flathead
    53Flathead
    from Kansas
    Ok, probably a dumb question but I will go ahead and ask. How can I put a tach in my 53' that is still 6 Volt?
  2. Dobie Gillis
    Dobie Gillis
    Get a 6 volt tach and wire it up as you would any other tach. I'm pretty sure a 12 volt tach won't work correctly or at all on 6 volts.
  3. 53Flathead
    53Flathead
    from Kansas
    Dobie, where can you get one at? Locally I am not having any luck.
  4. Mark T
    Mark T
    I think some of the older tachs would work on either you just had wire them differently.
    I may have an old 6 volt tach if your in the market for one.
  5. Dobie Gillis
    Dobie Gillis
  6. Merc cruzer
    Merc cruzer
    from Colorado
    This worked for me on my 53' 6 V Merc:
    Take this for what it is worth...I have a 6 volt POS ground system in my 53' Merc...I installed (temporally) a no name tach to check shift points and speed at different rpm's...it does have a switch for 4,6 & 8 cyl...voltage didn’t matter.
    4 wire tach:
    Black = hot (-) when swich is on
    Red = ground (-)
    Green = (+) side of coil
    White = head light switch
    2 wire tach:
    No switch for no. of cyl's - 8 cyl tach from an old Jeep
    one lead to (-) side of coil
    other lead to (+) batt (w/ switch - I did hook it up hot to the battery the first time and found that when you turn off the ign switch the motor just kept running)
