Hey, need your help I have a electric speedo from Stewart Warner, can I wire it to my T5 electronic speed sensor? Thanks for your help Pete
If it is the same as mine, there is a set of DIP switches on the back of the case. Setting these will configure the speedo to recognize the pulses generated by the output of the T5. There should have been an instruction sheet shipped with the speedo. Hit the s-w site and/or call their technical support or hopefully there is an automotoive instrument repair shop near you. http://www.stewartwarnercanada.com/media/pdf/install_instructions/B-764%20115067%20Speedometer.pdf http://www.stewartwarnercanada.com/media/pdf/install_instructions/NewSWSpeedo.pdf HTH
