Technical How Would You Fix This?
Discussion in 'The Hokey Ass Message Board' started by GearheadsQCE, Mar 15, 2019.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    1937 Chevrolet car headlight ring. These are not reproduced (yet). I believe these were a 2 year only item ('37 & '38)
    How would you go about a repair. I posted both sides so you can see how it's supposed to look. I know some of you tin knockers could make patches and weld them in. That's not in my skill set. The materiel is REALLY THIN, especially around the deep pits and rust throughs.
    Thinking I could remove the rivets that hold the screw clamp parts on, put a layer of fibergl*** cloth with epoxy resin on the inside and then finish the outside with Duragl***. All this while looking for a suitable replacement.
    I know this isn't a permanent fix but I can't spend thousands in labor to have @Flop do it.
    Does anyone think they could make one with a bead roller?
  2. tb33anda3rd
    tb33anda3rd
    no need for the cloth, any reenforced filler will do the job................for a while.
  3. Flop
    Flop
  4. pumpman
    pumpman
    And, as usual Flop to the rescue.
    kidcampbell71 and tb33anda3rd like this.
  5. Silver solder or brazing, then sand back to shape.
    Automotive Stud and sunbeam like this.
  6. saltflats
    saltflats
    from Missouri
    I was going to say, use one of those welding rods the guy at swap meet sells that he welds up the holes in the soda can.
    Or should say solder.
  7. Flop
    Flop
    saltflats and nochop like this.
  8. F&J
    F&J
    Don't overthink if you may get good ones later. Modern epoxies work fine on those. I would not bother taking the rivets out unless you want to sandblast the hidden rust which will continue to rust, even just from washing the car.
    If you want it to be permanent, then do take them out to blast, but rivet or screw them back together before using the epoxy, so you don't have to spend so much time sanding the insides where the brackets need to fit properly.
    Life is too short to get ****. It's just a car part.
  9. G-son
    G-son
    from Sweden
    How about lead? While it isn't a very strong metal, unlike modern fillers it IS metal, sticks well to steel and is plenty strong to fill pits and holes.
  10. Sporty45
    Sporty45
    Would JB weld work?
  11. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  12. Flop
    Flop
  13. Mr48chev
  14. fastcar1953
    fastcar1953
  15. Flop
    Flop
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I appreciate you guys and your input. The thing about this is that the light is kinda oddball. The Chevs of the 40's unit is for the larger truck light. They DO NOT have one specifically for the car. I thought about cutting the truck one down. Just wondered if anyone else had already done that or had a better suggestion. Maybe other GM divisions use the same part, but I have no way to verify .
    I will check further into the Jeep piece, but the clamp on part is pretty critical.
    Just so you don't think I'm too stupid, I did do some searching before posting.
    Note: It doesn't have to be chrome. Actually, I would prefer plain.
    Really nothing to lose on trying any type of filler.
    Thanx, and keep it coming!
  17. rudestude
    rudestude
    This seems to look like the one you have .....if it is then I must be a odd ball for having one....yes ...that's all I could find in my headlight bucket box...so far.. the headlight is a 7" B-L-C Headlamp...and I have only this one...all the others ,different brands, are paired up....here's some shots of it... 20190315_150500.jpeg 20190315_150554.jpeg 20190315_150827.jpeg 20190315_150842.jpeg 20190315_150906.jpeg 20190315_150935.jpeg 20190315_151048.jpeg 20190315_151103.jpeg
    Sent from my SM-T387V using The H.A.M.B. mobile app
    F&J likes this.
  18. rudestude
    rudestude
    Well I dug a little deeper and found a chrome one...there are some very slight differences...but the dementions and shape seem to be the same... 20190315_163141.jpeg 20190315_163204.jpeg 20190315_163247.jpeg 20190315_163437.jpeg 20190315_163505.jpeg 20190315_163556(0).jpeg
  19. F&J
    F&J
    If it will fit, then those are available as repro...it's some company that also makes the BLC tags. Somebody here will know where. I just don't know if they make a painted one.
  20. pitman
    pitman
    Tiger-hair epoxy.
  21. David Gersic
    David Gersic
    from DeKalb, IL
    Chevy of the 40s has new ones in chrome. They’re nice. I have a pair of painted originals if you’re interested. Not perfect, but much nicer than what you have there.
  22. oldolds
    oldolds
    Chev's of the 40's $90 each. Out of stock when I checked the website.
  23. 31Apickup
    31Apickup
    OTB has repro rings for BLC headlights, there is also a vintage Harley ring that is also suppose to interchange with the reprise being cheaper. I have the part number although I got it here on the HAMB
  24. woodiewagon46
    woodiewagon46
    from New York
    If you can't get a new headlight door, McMaster-Carr has a, Hi-Build brazing rod PN 7675A3 that flows "thicker" and would work for the blow thru's. The pitting, you can use solder. I would talk to your chrome plater first, he may have someone that can do it.
  25. David Gersic
    David Gersic
    from DeKalb, IL
    I&I was $80/pair when I bought mine a couple years ago. $90/pair now.
    https://iandireproduction.com/1937-38-Headlight-Rims-Chromed_p_423.html
    But also out of stock. Maybe call them, see when they’ll be back in stock. Offer stands on the painted originals. PM if you’re interested. Weather is starting to improve, I can probably get in my shed again, that’s where they’re stored.
  26. stillrunners
    stillrunners
    from dallas
    Not in a hurry ? This is a headlight ring correct - or a fog light ring ?
  27. Joe H
    Joe H
    Go to your local Harley Davidson store and purchase some aftermarket trim rings for a '49 - 59' Panhead, they fit just like the OEM Chevrolet trim rings. I would bet they were made by the same folks back in the day. https://www.billscustomcycles.com/panhead/headlight-ring-1174 I paid $8 each for mine back in '01. I converted to Halogen headlights, thats why the gl*** looks funny.
  28. RDR
    RDR
    Filling Station Part # GR47 $90.00 PR..37-38 Car Chrome 800-841-6622
    SAME STORY HERE.....on B.O.
    Sorry....
    1937-38 P***. CHROME HEADLIGHT RIMS
    These are reproduction chrome headlight rims (bezels) for 1937-1938 Chevrolet p***enger cars. Replaces GM# 920798
    Specific Applications:
    1937-1938 P***enger Cars - Models GA, GB, HA, HB
    This part fits most 1937 1938 Chevrolet Cars; exceptions may apply. Please read the complete description to see if this part fits your specific vehicle and application.
  29. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Wow!
    This just keeps getting better.
    I knew I came to the right place to ask.
    It seems that there were repops made but not anymore.
    You guys are the best.
  30. PHIL COOPY
    PHIL COOPY
    Silicon Bronze rod and a 000 tip.....you can fill in all the pinholes and it sands easily.
