How Would You Get Your Paint To Look Like This?
Discussion in 'The Hokey Ass Message Board' started by Slammed88, Oct 18, 2006.
  1. Slammed88
    Slammed88
    from Canada
    I was wondering if anyone knew how you would go about making your paint look like this:
    It's not really flat paint, but it's not as shiny as regular paint. It looks like a good paint job that has been weathered (Probably because that's what it is! Haha!)
    Is there any way to make the paint look weathered (like the picture) without having to let nature take it's course?
    Thanks!
  2. Gotgas
    Gotgas
    from DFW USA
    Paint it with John Deere Blitz Black. It's a semigloss black.
    Or add flattener to the clear coat of a normal paint job. Don't add enough to make it truly flat.
  3. ratstar
    ratstar
    Or just get an old car with that paint.
  4. Slammed88
    Slammed88
    from Canada
    Haha, I would if I could.
  5. fatabone
    fatabone
    Take the paint off that one and put it on yours.:D
    Like Gotgas said use a flattener in the clear coat.
  6. Slammed88
    Slammed88
    from Canada
    I think it's a little more glossy than the John Deere Blitz Black, but I'm not sure.
  7. briggs&strattonChev
    briggs&strattonChev
    I agree
  8. BinderRod
    BinderRod
    You could buy an old can of paint that has been sitting outside
  9. seymour
    seymour
    from PNW
    that car looks wet
  10. guiseart
    guiseart
    That's a faded black car with dew on it man.
  11. 3wLarry
    3wLarry
    from Owasso, Ok
    seymour's pretty quick, ain't he?...:D
  12. Gotgas
    Gotgas
    from DFW USA
    Then add some glossener to that. :D
    Or rub it with oil...
  13. Try flattening agent in various degrees on test panels to see what you get.
    Or just use laquer with no clear - it'll look like like that in a few months of being outside.
  14. seymour
    seymour
    from PNW
    nothin gets past me!
  15. mazdaslam
    mazdaslam
    Hahaaaaaa.......:p I almost fell out of my chair with that one!!!
  16. Comet
    Comet
    I have gotten a similar effect by stopping at the medium grit compound from 3M. It's like a gel, not a paste. I found this stage to be the best because any finer left it too glossy, and grittier and you saw swirls.
    Disclaimer: I'm not a painter so just beware if you take my advice...it wasn't my fault!:D
  17. brandon
    brandon
    spray the last coat dry.....dusting it on ......did a harley tank for a customer with the blitz black .....went on like semi gloss ....went over it with a dusting.....flattened right out....same for dp90......it looks like gel coat if ya spray it wet......brandon
  18. kroozn1
    kroozn1
    Or just use cheap single stage old style enamel without hardener and thinned with cheap lacquer thinner.
    It won't take long in the sun to have the aged look!
  19. Bugman
    Bugman
    Take the glossy paint and scuff it with 0000 ultra fine steel wool.
  20. roddinron
    roddinron
    I never did it, but you could probably just wash the car with cleanser, try Bon Ami first since it is less abrasive.
  21. pimpin paint
    pimpin paint
    from so cal
    Hey,
    Martin Seinor/NAPA use to, and perhaps still does sell a paint called
    " Ch***is Black". This was for use on core supports, splash aprons
    and yeah, the ch***is. A semi-gloss finish, without all the silly flat-
    ner in the clear that's gonna take a **** asap!
    S****ey devils C.C.
  22. JohnnyP.
    JohnnyP.
    you can get a complete flat color by just spraying ppg base coat. its thick enough to where it wont fade but make sure you use a sealer and put plenty of base on. you can not do this with dupont.
  23. Tim
    Tim
    from KCMO
    seems like no one realizes that you want a car that looks like it was painted glossy black 50 years ago and is still holding up 'alright'
    i know what your talking about
    paint it single stage glossy black, and then sand and buff the **** out of it until it turns into that "worn" look.
    tim
  24. If you really want it to look weathered, this sounds like a good approach, I've seen this done. Also can disregard the directions on any catalyzed paint searching for a reaction(like drying overnite before spraying the second coat)-----------LEE
  25. Detonator
    Detonator
    from santa cruz
    Shoot it with a cheap gloss paint, then rub it out with Ajax cleanser. Then park outside in the sun and rain for a few months.
  26. devinshaw
    devinshaw
    I have achieved a similar look with black acrylic enamel flattened 20% and shot just a little dry.
  27. VonMoldy
    VonMoldy
    from UTARRGH!
    take it to maaco.
    Why would you want faded paint?
    Shiny paint is old school!
  28. PSYCHOMOTO
    PSYCHOMOTO
    is this car for sale?????????????
  29. hotrod54chevy
    hotrod54chevy
    from Ohio
    seriously,i think the car is just dewy...my 54 has shiney paint on it and when it gets wet or dewy it looks flat like that
    creepy
  30. 49ratfink
    49ratfink
    paint it with cheap gloss enamel at night outside at about 37 degrees. no hotter than 42.
