Technical how you guys mounting A radiators?
Discussion in 'The Hokey Ass Message Board' started by lostone, Jun 2, 2019.
  1. lostone
    lostone
    from kansas
    1931 A tudor, 440 auto, aluminum radiator, commercial grille shell I cut down 3".
    Ok with the specs listed I have a question for you gents. I'm moving the radiator forward 2 inches and I was wondering how you guys handled doing this on the mounts?
    Do you mount a piece of strap to the bottom of the radiator solid and then where the strap mounts on the frame put the rubber and bolt/spring ***embly in its original holes or the opposite? Mount the strap solid to the frame and the rubber and spring/bolt ***embly to the radiator or does it really matter ??
    I tried the search but had no luck finding an answer.
    Any help would be appreciated and posting pics to show would be worth even more brownie points!!
    Rich B. likes this.
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    If it's not going to sit on the k member, prob something like this...... I'm in the same boat. This is just for reference...... Gives an idea.....
  3. moparjimd60
    moparjimd60
    I moved mine forward by cutting 2 pieces of 3/16” flat and bolted it to the stock holes on the crossmember then drilled holes for the radiator to bolt to moving it 2” forward works like a champ
  4. lostone
    lostone
    from kansas
    Thanks guys, I was leaning to the strap to frame method myself. I figure it might be a good idea to add a tack weld to 1 side to keep the straps and radiator from be able to move sideways
  5. Corn Fed
    Corn Fed
    I did it by leaving the radiator in the stock location on top of the cross member, moving the engine back, and recessing the firewall.
    Nailhead Jason and missysdad1 like this.
  6. 41rodderz
    41rodderz
    from Oregon
    LOL
  7. missysdad1
    missysdad1
    I hate it when some smart*** chimes in and tells everybody how it should be done the right way. :rolleyes: Corn Fed is right. Moving the radiator forward for engine clearance is the quick and dirty way to get it done but it totally messes with the esthetics of the car, giving it a Pinocchio look. This doesn't seem to bother a lot of guys but it just ruins the car for me. Take Corn Fed's advice and do it right.
    Nailhead Jason likes this.
  8. oj
    oj
    I made a seperate support for mine inside the shell, that lower support has its own support strap running up to the bracket that bolts to the frame.
    Heres the outside
    And the cover that I'll get chromed:
    That way none of the radiator weight is supported by the shell. the bracket bolting it akk to frame has springs loading the bolts similar to how Ford did it.
  9. lostone
    lostone
    from kansas
    Thanks guys,
    I don't think 2" will hurt the looks that much, besides I want the interior space. With a 3" channel and a 2 1/2" chop I'd rather keep as much inside room as I can. I want to be somewhat comfy driving it.
    OJ, that's really slick. I like the way you handled it. ;)
