HP calculation help
Discussion in 'The Hokey Ass Message Board' started by xRONMOWERx, Dec 16, 2009.
  1. can anyone tell me how to calculate horsepower using the block,head specs,cam specs,piston type and intake?
  2. hotrod-Linkin
    hotrod-Linkin
    welcome ....who are you??
  3. skullhat
    skullhat
    put it on a dyno
    skull
  4. im just a guy thats been lurking around here in the shadows for a while trying to soak up the knowledge ive found here and enjoying the treads.
  5. Jimv
    Jimv
    intro yourself. I don't think there is anyway to "calculate " HP without a dyno
    JimV
  6. AGFuels
    AGFuels
    from NC
    I suggest you consult "Internal Combustion Engine Fundamentals" by Dr. John Heywood (MIT...And that's not Mississippi Institute of Taxidermy.) It'll help you determine IMEP and BMEP. With thoses values, engine displacement, speed (RPM) and a few other things you can arrive at brake horsepower plus or minus a tad.
    Regards.
  7. olddrags
    olddrags
    from ky
    WOW thses FNG are amazing!!
  8. squirrel
    download this old DOS shareware program called Drag Strip Plus, and have fun! don't expect too much accuracy though...
  9. skullhat
    skullhat
    i dont think you can calculate hp with the varibles you mention. if you know the wieght and a 1/4 mile time etc and speed there are formulas for the hp neccesary.
    i know some guys who add up all the hp you are supposed to get with each mod and think thats what you end up with.....:)
  10. 29nash
    29nash
    from colorado
    First find a Proney Brake Machine.
    Formula is;
    PLANK
    33,000
    P - indicated mean effective pressure
    L - length of stroke
    A - area of piston head in square inches
    N - number of power strokes per minute
    K - number of cylinders
  11. squirrel
    I like that suggestion best
  12. 333 Half Evil
    333 Half Evil
    I just use the fact that all internal combustion engines are capable of producing a given amount of HP and/or TQ per cubic inch. This is based on engine design(stroke/bore/rod length/reciprocating weight/valve size/runner efficiency/total intake runner-vs-plenum volume/etc.) and are as follows:
    SBC: 2hp/ci
    BBC: 2-3hp/ci
    Early Hemi:1.25hp/ci
    Late Hemi: 1.75hp/ci
    SB mopar:1hp/ci
    BB mopar:1.125hp/ci
    SBF: .5625hp/ci
    BBF: .75hp/ci
    I do have the formulas for other engines as well, just email me at boydoiknowhorsepowerandasyoucanseeilikesbcnbbcmuchmorethananythingelse@imayahoo.com
    and tell me what engine you have and I will give you the correct formula.
  13. lippy
    lippy
    from Ks
    Nitro or alky, gas or steam?
  14. squirrel
    lmao
  15. hey I have desktop dyno, it only takes a second if you have the specs
  16. scottybaccus
    scottybaccus
    you scared him off.....
    I still don't see an intro or I might share a tip about the free software from a major cam manufacturer that is probably the best bet in a shadowy world of optimistic bullshit and blind hope....
  17. 333 Half Evil
    333 Half Evil
    COME ON SCOTTY...Ok, fine I'll intro him. He is xronmowerx, he is a fng from Ohio. I think he is into mowers. He has a question about hp calculating and after lurking around here for some time he finally decided to join and ask for our/your help....now what is this free stuff you seem to want to keep secret?
  18. Shaggy
    Shaggy
    from Sultan, WA
    What about nash 6??
  19. squirrel
    could be the Comp Cams "Cam Quest" software that you can download at their web page
    http://www.compcams.com/camquest/default.asp
  20. Hahahaha.... reminds me of the old flathead hop up books from the 50s and 60s. Carbs... 10-15hp
    Port and relieve... 10hp
    Cam... 10-15hp....
    Heads.... 10hp
    Bore and stroke .... 10-20 hp
    etc, etc......
    so simplistic, so easy, so a load of bollocks.... :D
  21. ThePuck
    ThePuck
    from Ottawa
    Take the intake port flow in cfm and multiply by 2 to get a rough idea of most engines HP 'potential'.
  22. holeshot
    holeshot
    from Waxahachie
    RON...there is definantly a way, but i don't know anyone on the planet who can do it accuratly. and neither do they...POP.
  23. OoltewahSpeedShop
    OoltewahSpeedShop
  24. 333 Half Evil
    333 Half Evil
    Shaggy,
    The Nash six comes in at .6125hp/ci That is just above the SBF!!
  25. uglydog56
    uglydog56
    I always use head cfm x2 and multiply by a guess of volumetric efficiency (75% for stock heads, 85% for good aftermarket street, 100% for the hairy ones) and that should get you close, assuming nothing blatantly doesn't match.
    Another good one is to take what you think it makes and subtract 100hp, that's usually close......
  26. scottybaccus
    scottybaccus
  27. panic
    panic
    SBC: 2hp/ci
    BBC: 2-3hp/ci
    SB mopar:1hp/ci
    BB mopar:1.125hp/ci
    SBF: .5625hp/ci
    BBF: .75hp/ci
    You should really point out that "this is a political and sarcastic comment", lest you frighten some of the children.
  28. 333 Half Evil
    333 Half Evil
    Panic, look closely at the email address I put in that same post....read it slowly, seperating it into words....that should explain it all!!! :D
  29. That's like trying to calculate how good someone is in bed based on their stats and measurements.
    Is it me or can you come up with a sex analogy for almost anything engine-related?
  30. I use a program all the time in my engine business. We can alway come with in 2 /10 of a second in modeling a car and chassis set up and engine. Occasionally we have been right on the money. The modeling programs for engines are very accurate IF YOU DONT LIE to them. I will do you one of you like. Send me your specs by PM.
    By the way half evil, The day a sbc makes more hp per cubic inch than a hemi will be a frosty friday in that evil place. Probably you are one of those dudes who tells people the small block chevy was the first North American engine to be produced with more than 1 hp or more per cubic inch. WRONG!!!!!!!!!!! 55 Chrysler 300 A early hemi was.
    It takes a huge cubic inched BBChev to produce 800 plus hp. A superstock 426cu in say 69 cuda SS/A have been approaching that for several years. You chevy guys always have your bowties tied a little tight I think.
    Don
    If one just wants a quick idea you can use cam lift /500 X cu inches . It isnt super accurate but is a good ball park for street hp. (for cam lift use for instance 550 not .550)
    PLANK is theoretical hp and is not relavent to anything other than licensing by hp rating perhaps.
    HP = rpm X torque in ft .lbs divided by 5252
    Torque and HP should always be the same at 5252 RPM
