HRLC is broke down
Discussion in 'The Hokey Ass Message Board' started by enjenjo, Oct 9, 2011.
  1. enjenjo
    enjenjo
    from swanton oh
    She is near south bend in. or elcart in. Electrical problem, possibly a fuesable link. Any electric wizards near by?
  2. monsterflake
    monsterflake
  3. flamedabone
    flamedabone
    She puts over the road trucker style miles on that little car... You can't fault it for needing a hand once in a while.
    Good luck, -Abone.
  4. enjenjo
    enjenjo
    from swanton oh
  5. The only thing I can do to help is bring this thread back to the top.
  6. to the top for Denise.
    Sure hope she can get back up and running soon.
  7. oj
    oj
    Can you get a description of the problem and post it?
  8. ratster
    ratster
    someone help her
  9. bobwop
    bobwop
    from Arley, AL
    I would if I could
  10. hotrodladycrusr
    hotrodladycrusr
    Car died at slow speed and won't restart. First time tried to start it after him dying there was a puff of smoke from the area of steering column drop. Tumbler turns, gauges come on, but that's it. Flatbed on the way. I'm having him towed to Battle Creek michigan so I'm closer to home. Hamb guys house but he's not home.
    Would like truck and trailer from battle creek to livonia or maybe just a ride for me home and I can go back and pick up the car later.
    Or if someone in the BC/Kzoo area that might be willing to look at issue today??
    Thanks
    Oh yeah Pileup was a BLAST!
  11. enjenjo
    enjenjo
    from swanton oh
    Driving down the road, it quit at speed, no warning. It will not crank, no electric power anywhere. Starter replace 1000 miles back. I am thinking fueable link bad, or broken wire at the starter.
  12. Mr48chev
    Does she have a test light or volt meter in the car with her? Maybe someone can walk her through testing the circuit on the phone.
    It looks like we we all typing at the same time. It sounds like a short in or around the ignition switch.
  13. brokenspoke
    brokenspoke
  14. Special Ed
    Special Ed
    If she says her gauges are working, and you're saying no electrical power anywhere, we can't help too much...
  15. inline 292
    inline 292
    A couple jumper wires, one to the coil & other momenterily to the starter relay will fix a lot of problems.....on a good day. Wish I was closer.
  16. Mr48chev
    That would work if she wasn't getting any power to the inside but might not be the best thing to do with the short under the dash or in the column.
  17. oj
    oj
    I think she has it under control getting a rollback. The problem sounds like at or around the ignition switch since all ignition stuff come from it but the dash lites etc are independant of ignition and don't need 'key on'.
    Since the car died but won't crank over i would have a looksee at the switch supply wire - i am ***uming her olds is rewired/updated and it'd be a tough guess where its' origin is.
  18. 61falcon
    61falcon
    any updates??
  19. raidmagic
    raidmagic
  20. zman
    zman
    from Garner, NC
  21. nexxussian
    nexxussian
    Sombody's gotta be in Indiana. :confused:
  22. enjenjo
    enjenjo
    from swanton oh
    She had not told me about the guages when I posted. I talked to her again, did some quick and dirty testing over the phone. The next time she tried it, the carb started smoking, still no crank, It may be a broken ground. I had her disconnect the battery cables until it can be checked out properly. I don't want her to have a fire.
  23. oj
    oj
    Good thinking
  24. brokenspoke
    brokenspoke
    Any updates? is she safe?
  25. 48fordnut
    48fordnut
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
    anything on this yet?
  27. lothiandon1940
    lothiandon1940
    Good luck with the fix, Denise. Keep us informed when you're safely home. Hopefully Big Olds will be a simple repair.
  28. tfeverfred
    tfeverfred
  29. Mr48chev
    There two threads going on this as it looks like Enjenjo stuttered when he posted the thread.
