Technical Hub puller
Discussion in 'The Hokey Ass Message Board' started by fordpatina, May 9, 2024.
  1. fordpatina
    fordpatina
    I think this is a good idea when you don't have a brake drum puller
    leon bee likes this.
  2. '29 Gizmo
    '29 Gizmo
    from UK
    A hub puller can apply tons of load if require to pull off a taper axle. A scissor jack only a fraction of that.
  3. That looks like a good way to get hurt.
    vtx1800, Squablow, Hotrodmyk and 5 others like this.
  4. x2 on Truckdoctor Andy said. Renting the right tool will save you time, aggravation, and possibly worse. Buying a tool you will rarely use is still probably cheaper than the co-pay at the ER if you get hurt trying to do it without the right tool.
    AVater and VANDENPLAS like this.
  5. jimmy six
    jimmy six
    This is funny…. Something you would see in “just rolled in”
  6. tubman
    tubman
    Looks like something from one of those "Indonesian Auto Repair" videos on "YouTube".:eek:
  7. 57 Fargo
    57 Fargo
    Looks like a clever way to solve a problem if you don’t have the “proper” tool
    j hansen likes this.
  8. Mr48chev
    That's not a hub puller, they are trying to pull the drum off the axle but how the hell did they get those bolts hooked to the drum? Or are the screwed into the axle flange? By the size of the bolt I think they took the screws that hold the drum on the axle out and have those bolts screwed in the same holes.
    jaracer likes this.
  9. Looks like you need more than two hands to make it work. Probably just fall over with a bit of tension.
