hub to hub measurment ?
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Mar 30, 2009.
  1. hillbilly4008
    hillbilly4008
    from Rome NY
    I just brought home my 9inch and it looks too narrow for my app. I have a banjo out of a '46 Ford 1/2ton pickup now. With the tires on theres only about 3/4" - 1" between the tire and the body. The 9inch is out of a '70 Bronco.
    Can anyone help my find out what the hub to hub measurments for both axles are? I dont have anybody to hold the other end of the tape.
  2. 19Fordy
    19Fordy
    Solution: Remove both wheel from the rear. Get a paint stir from HomeDepot and snug it down finger tight between using a lug turned upside down. Now that paint stick will stick out beyong the brake drum and be parallel with the axle flange. Do the same thing on the other side with another paint stick. Now measure outside to ouside from the edge of the paint sticks and subtract the thickness of the two paint sticks.
  3. dirtbag13
    dirtbag13
    bronco should be 58 inches !
  4. dirtbag13
    dirtbag13
    also if theres not much differance you could use some wheel spacers , just a suggestion ?
  5. hillbilly4008
    hillbilly4008
    from Rome NY
    yeah, not a big fan of wheel spacers. I cant justify spendin over 100bux on a chinzy aluminum ring with holes drilling in it. Besides that, MOST OF EM ARE BILLET!
  6. Try making a set out of stainless steel.
    You'll probably become a 'billet' enthusiast after that....
  7. haha thats funny.
    my bronco rear measures 58 inches, same as my banjo.
  8. mtflat
    mtflat
    The one you have now is right at 61.25" hub to hub. If your clearance is too close now, one option is a 9" from 73 up F100/150. They're about at 3" wider, giving you an extra 1.5" per side.
  9. bob hindman
    bob hindman
    what is the norressst.....
  10. dirtbag13
    dirtbag13
    narowest 9 inch is a 57-59 ford at 57 and 3/4 inches !
  11. dbradley
    dbradley
  12. 4tford
    4tford
