Hubcap security / retaining???
Discussion in 'The Hokey Ass Message Board' started by foxcustom, Apr 30, 2011.
  1. foxcustom
    foxcustom
    from Detroit,MI
    I have a set of original (full) '59 Impala hubcaps that I have been running on my stock '59 Impala wheels...so that combination is correct. But, I have been having problems with the hubcaps just popping off now and then. No serious damage to the hubcaps YET, but I don't want to chance losing one or getting it run over.
    Anyone that has run caps, do you have any tricks on how to hold the hubcap onto the wheel in a really secure way???
    If anyone could that'd be great.
    Thanks
  2. 28dreyer
    28dreyer
    from Minnesota
    Had that problem big time on my race car trailer. Old mobile home axle and God knows what 15 inch wheels. After 15 years of losses I finally drilled 3 pairs of evenly spaced 3/32nds holes around the the wheel at about where the openings in these Ford Hubcaps were and threaded safety wire thru the holes in the wheels, through the openings in the caps and used a safety wire twister and tucked the cut ends back in through the openings.
    Hardly noticeabe and effective and easily re-do able if needing to pull the cap off.
  3. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Honestly no ****, after losing cadillac caps once or twice I siliconed the next set onto the wheel. If I ever needed to get it off I could cut the silicon with a razor blade but it never came to that. Worked like a charm!
  4. foxcustom
    foxcustom
    from Detroit,MI
    Alright Cool idea and definitely easy.
    Anyone else out there havin the same issue?
  5. foxcustom
    foxcustom
    from Detroit,MI
  6. farmer12
    farmer12
    That sounds like a good idea. May just have to try that!
  7. hemifarris
    hemifarris
    Do your wheels' outer rim have 3-4 raised nubs on them? Original 58-59 Chevrolet wheels had raised nubs on them. I can't remember whether it was 3 or 4. The nubs are retainers for full wheel covers. I put 15" rims on my El Camino with dog dish caps but I still have the stock wheels, new wide whites and a N.O.S. set of '59 wheel covers with original spinners......Mike
  8. foxcustom
    foxcustom
    from Detroit,MI
    Yes sir. They have the nubs. I'm just gonna bend the mounting tabs out on the caps and cross my fingers.
  9. stuart in mn
    stuart in mn
    Are you running radial or bias ply tires? I've heard radial on older wheels can make them flex more.
  10. ponchopowered
    ponchopowered
    done the siliconed thing on my pontiac when i was running my 55 dodge royal lancers, worked like a charm
  11. foxcustom
    foxcustom
    from Detroit,MI
    Radials....
  12. tb33anda3rd
    tb33anda3rd
    write your name and phone number on the backside with a paint pen. just in case they do fall off.
  13. sololobo
    sololobo
    J, J,' soulution is slick as is the saftey wire. Good tech post kids, tough to lose some of the vintage discs. Right on ~sololobo~
