Hudson exhaust manifold
Discussion in 'The Hokey Ass Message Board' started by VOLKER, Nov 15, 2009.
  1. VOLKER
    VOLKER
    Anyone ever seen a dual exhaust manifold for the hornet 7x raceing engine?
  2. hotrod-Linkin
    hotrod-Linkin
    not for the racing engine. i do build hudson split manifolds. have done a few for the HET guys. don't know what they put them on.
  3. Yes, took these pictures 40 years ago and scanned the prints but that is a genuine factory 7X exhaust manifold and Twin H with it in the pics. That is the factory headpipe too that went two into one to comply with NASCAR rules that a 6 cyl car could not have two tail pipes past the rear axle. I don't own this setup any more but I used to have it on a '53 SuperWasp brougham with twice pipes and gl*** packs all the way out.
      214.1 KB
      200.7 KB
  4. ratwasp
    ratwasp
    are you still building/selling the Hudson split manifolds?
  5. Hud I
    Hud I
    from Tennessee
    Clifford makes headers for the engine. Clifford Performance com. hope this helps Hud
  6. ratwasp
    ratwasp
    Thank you, I will check Clifford out!
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Since it's just an extension that bolts to the standard exhaust manifold, it seems like someone would be recasting it.
  8. Ebbsspeed
    Ebbsspeed
    I believe the manifold has two separate outlets, and that extension also has two ports through it. So while they are both single castings, they do keep the exhaust from the front three cylinders separated from the back three until it hits that steel pipe collector.
  9. Hud I
    Hud I
    from Tennessee
    The 7x extension is being recasted. Some gentleman in Al. is doing it. Go over to cl***iccar.com and get on the Hudson board. They will point you in the right direction. Hud
