huge hole vs. sheetmetal screw
Discussion in 'The Hokey Ass Message Board' started by 51chingon, Mar 21, 2013.
  1. 51chingon
    51chingon
    from union city
    I'm installing my interior window trim, and it seems the holes in the doors for the screw have been oversized over the years.
    I've tried using larger screws but they don't look right and they only grab half the time'
    Are there any suggestions.
    Thanks in advance
  2. falconsprint63
    falconsprint63
    from Mayberry
    weld up then re-drill the holes
  3. john~N~dallas
    john~N~dallas
    What he said ..
  4. Edsel58a
    Edsel58a
    times 3..... after some thought, if welding is out, Magnum steel epoxy then drill.
  5. inthweedz
    inthweedz
    Bend a piece ( about 3/4'' long) of 1/16 welding wire into a U shape, slip one end into the hole, so it hangs either side of the hole, then screw away. This will give the screw thread something to hook into, and tighten up.. I've used this trick many times, it works..
  6. if you're looking for a quick fix and you can get to the inside of the panel, use a speed nut. if you want to do it right weld and redrill
  7. bobss396
    bobss396
    If you have access to it from behind, rivet a nut-plate on the farside and it'll be as good as new.
    Bob
  8. drptop70ss
    drptop70ss
    from NY
    Piece of paperclip usually works great used this way as well if you do not have a welder. I put a quick buzz with the mig to make the hole smaller.
  9. I was gonna say paperclip or mig wire:D
  10. Roger Walling
    Roger Walling
    A tip when making a hole for a screw, don't drill, use a very sharp ***** punch backed up by something heavy with a small hole in it,
    The conacal hole that you will produce will only get tighter when you tighten up the screw
  11. Welding might not be a good option sometimes -
    There's a few ways to skin that cat
    The wire bent into a U works
    A nut sert into the hole and threaded screws
    A large aluminum rivet into the hole with a bit of panel bond epoxy on The head- run your screw into the center of the rivet.
    You can also rivet a back up plate over or behind the hole and drill it.
    Jb weld blob on the back side and drill Into it
    Use your imagination depending on what you are holding
  12. tikiwagon13
    tikiwagon13
    you can use a rivnut, you don't need access to the inside of the door and you have a bunch of coices on the size you can use.
  13. TurboX2
    TurboX2
    I have used plastic plugs such as anchors for drywall (depending on size of hole) and other type that are made for late model door panels. Fills,seals,and deadens!
  14. OLDTGUY
    OLDTGUY
    I use small cotter pins, spread apart, bend end into hook, and the flat side will help hold them in place.
    JJ
  15. GregCon
    GregCon
    from Houston
    Well, it's good to know that shadetree mechanics are still alive and well. Let me guess....you put oatmeal in your radiator to stop leaks, too?
  16. The wire method you are referring to is 100% viable and a variation on a very old carpentry trick .
    This oatmeal in the radiator idea of yours is complete nincompoopery
  17. Smilin Jack
    Smilin Jack
    Black pepper
  18. gas pumper
    gas pumper
    +2 with the pepper
  19. Mike51Merc
    Mike51Merc
    Sometimes if you can get behind the hole, you can hammer it flat and it will take a small screw again.
  20. EchoOfGecko
    EchoOfGecko
    Would a screw clip work? I use these a lot even for good holes, I'd rather the screw bite into one of these than a painted panel.
  21. I've used these before too. Some times I've had to flatten them out and rivet thru the flat part so that the holed part is in the correct location
  22. HOTRODPRIMER
    HOTRODPRIMER
    Exactly what I was thinking,,sometimes thinking out side the automotive solutions you'll find what you need.
    You can find the anchors at any home improvement store. HRP
  23. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I've cut the flat off and it works great if you can get to the back side. It's the ultimate fix for fibergl*** panels, too.
  24. EnglishBob
    EnglishBob
    Really?,I suppose you cut the door jamb out, fabricate a new one over your knee and then get out your 80 year old hand drill and drill new holes?
  25. black 62
    black 62
    from arkansas
    worked great for me...
  26. Rat.Racer
    Rat.Racer
    from Maryland
    Well said!
  27. belair
    belair
    Good info. I knew about using a piece of wire, but the other solutions are good to know.
  28. Mr48chev
    Good info to remember. the screw holes for the screws that hold the sunvisors on my "other" pickup are too big for the correct screws probably due to my uncle over tightening them for years on end. I didn't think about putting the tin nuts on the back side of the panel for door mirrors either.
  29. GregCon
    GregCon
    from Houston
    I used to think the bent wire trick was great. Then, I turned 12 and I started to think it was for cobblers. By the time I turned 13, I was sure of it. Funny how age brings wisdom.
  30. Turbo26T
    Turbo26T
