Hot Rods Humble beginnings... Lets see if I can finish this one...
Discussion in 'The Hokey Ass Message Board' started by hillbilly4008, Jun 5, 2012.
  1. Beau
    Beau
    I wear a respirator. That dust is not good! Who knows what's in those cheap cut-off wheels.
  2. hillbilly4008
    hillbilly4008
    from Rome NY
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    I finished both wheel housings today. Then attempted to square up the carc*** by myself, problem is my arms are about 4feet too short to hold both ends of the tape measure.
    Baby steps
    Beau, just bustin' yur nuts about the mask. I should probably wear em more often.
  4. hillbilly4008
    hillbilly4008
    from Rome NY
    body is squared and braces are run, now the easy stuff begins!:D What a relief.
  5. prefect20
    prefect20
    from scotland
    Well done for making a car out of that collection of holes and tin.
  6. hillbilly4008
    hillbilly4008
    from Rome NY
    Nothing fancy, but here is where I am at now.
  7. Beau
    Beau
    Oh yeah! That's going to be a nice length for the tub.
  8. hillbilly4008
    hillbilly4008
    from Rome NY
    Well I F'ed up my whole weekend today. I decided not to go to the Buffalo show, and instead stay home so I could sell this '46 Willys jeep I had. Then take that cash and buy a Beverly shear tomorrow.
    While moving the jeep with my tractor this morning I hit something and totally destroyed the Jeep's frame. Goodbye sale, goodbye Beverly B3 shear. What a **** day. I ended up selling the Heep's body to a buddy of mine, and I decided to part out whats left. Who knows, maybe I'll make more parting it out? :rolleyes:
    I SOO WANTED THAT BEVERLY THOUGH!!!
  9. hillbilly4008
    hillbilly4008
    from Rome NY
    Man, in a strange turn of events my new girl Beverly came home with me tonight. She is purtier than her CL pictures. Shes still tied up in the back of my jeep, I'll get her out and post some glamour pics tomorrow.
  10. hillbilly4008
    hillbilly4008
    from Rome NY
  11. hillbilly4008
    hillbilly4008
    from Rome NY
    Figured I'd give a quick update. I haven't touched this car in more than a week, I've been to busy with other stuff. I decided to get off my **** and do maple syrup this year, little did i know its a lot of work.
    My stock 28-29 radiator came in. I'm hoping the local radiator shop can handle the task of adding the outlets for the flathead. It looks like there is alot less lower tank on the 28-29 rad than there is on the 30-31 rad.
    I've also decided that when it comes time to paint I am doing a brush job with an oil base paint. My son wants it to be green, so I'm sure I'll oblige. Rustoleum sells a Hunter Green, thats a bit dark but may work good with a black ch***is.
  12. Beau
    Beau
    Nice. I have been brush painting stuff as well. I have a buddy that works at Diamond Vogel and they have a new paint they were testing that can be applied to bare metal. A gallon is like $60. For ch***is stuff it'll be easy to touch up. I'm a normal person. I expect to mess up the paint.
  13. hillbilly4008
    hillbilly4008
    from Rome NY
    I needed my work table back, so I set the body on the ch***is.
    Keep in mind, its just setting ontop of the frame rails. It will get channeled down somewhere between 2''-3". I'm thinking about stufffing two small round tail lamps (think '33 Ford) between the body and the rear crossmember. I still have to cut the rear off the frame and move it back to where I started out with.
    I'm sitting here in my shop boiling down Maple sap, and working on the rod. Nice and peaceful, nobody hear but me and the voices in my head...:D
  14. Beau
    Beau
    Lookin good! I really like the body.
    I'll forward my address for some syrup. My lady uses it on EVERYTHING.
  15. hillbilly4008
    hillbilly4008
    from Rome NY
    I tacked in the package tray tonight. Then started on the seat sides. I just used a hammer and some exhaust pipe for a make shift hammer form, little trick a Mr. Gene Winfileld taught me. (yeah, I just name dropped)
  16. hillbilly4008
    hillbilly4008
    from Rome NY
    Motor mounts are back in there, and I FINALLY got to set the drivetrain in my ch***is. It looks like I have the perfect amount of clearance at the front and back of the engine. (again, note that the body will still have to be lowered over the frame AND I am getting a drop axle)
    I still am not sure how to do the trans mount. Though, it looks like a pretty straight forward job. I may have to trim that stock crossmember though.
    ...and I finally found a use for the totally obnoxious green laquer paint I have.
    Its actually growing on me, I may paint the body this color:D
  17. hillbilly4008
    hillbilly4008
    from Rome NY
    Back in the shop. I finally am at the point where I sorta know where everything is going to go. Today I did the trans mount, still needs to be dressed up a bit.
    The crossmember needed to be cut, there was noway of getting around it without lowering the engine. Truck waterpumps probably would've done the trick but I'd rather cut the metal that hunt for a pair of good usable truck pumps.
    My trans mounts. Simple 3x4x1/4 angle cut to a 3" length. 1.25" hole drilled 1.5 in and centered.
    all welded in
    Gusset ran underneath
    Now was also a great time to trim the rear of the crossmember for torque tube clearance.
    Still needs a bit of cleaning up and finish welding, but we'll worry about that when it all gets blown apart again.
    Now to move that rear crossmember AGAIN:(
  18. hillbilly4008
    hillbilly4008
    from Rome NY
    Frame is now where it belongs. Wheelbase is now 101.75'' way far from that 96''-98'' that I've been thinking.
    I had to shorten my torque tube by 25 3/4"
  19. hillbilly4008
    hillbilly4008
    from Rome NY
    Made and welded up the block for the rear bones to mount to the TT. Took a little manliness to squeeze the two arms together AND install the nut on the bolt, but I got 'er.
    Now it's on to the front split wishbone mounts. I plan to run the "newer style" tie rod ends, but really don't want to buy an off the shelf tapered mount. Any ideas?
  20. hillbilly4008
    hillbilly4008
    from Rome NY
    First roll out, this thing is gonna be a blast!:D:D:D
  21. hillbilly4008
    hillbilly4008
    from Rome NY
  22. hillbilly4008
    hillbilly4008
    from Rome NY
    And the money shot.
    The body is only channeled about 2", maybe a little less. The grill and radiator are stock. I honestly don't know if it needs to be lowered. Opinions?
  23. Uptown83
    Uptown83
    If whats needs to be lowered? The front? Yes
  24. hillbilly4008
    hillbilly4008
    from Rome NY
    The grill.
    The front is coming down via drop axle and tires.
  25. 29ToyA
    29ToyA
    Lower the front
  26. hillbilly4008
    hillbilly4008
    from Rome NY
    Yes the front of the car will be lowered.
    I'm asking about lowering the grill in comparison to the body.
  27. 4 pedals
    4 pedals
    from Nor Cal
    The grill needs to come down a couple of inches to look right. Run some tape lines from the grill to the cowl and it will tell you where it needs to be.
    Devin
  28. hillbilly4008
    hillbilly4008
    from Rome NY
    Went to a small private yard today.
    Bought a headlight bar from a '28 Model A, I'll be cutting that ****er up tomorrow.
    While I was leaving I noticed a spindle sticking up out of the dirt so I walked over and lifted it up. Wouldn't ya know it had an axle attached to it, along with the wishbone, and the main leaf spring. It looked to be a '32 Heavy axle, but I've been fooled before (damn truck axles:rolleyes:) It was hailing while I was there so I snapped some ****ty cell pics and stashed the axle until I could go back for it.
    Quick text to ***us and he confirmed that it IS in fact a '32 heavy axle! Now to go back and get it before someone else does!
    I love Sundays
  29. EliteS&C
    EliteS&C
    Hey Joe,
    You are doing a great job on this build! I really appreciate the effort you have put into this to save another vehicle from rusting into the ground! I too am currently building a very traditional AV8 as well. I am looking forward to watching this build through to the end. Keep up the great work.
    P.S. - I wish I had your luck with the flathead engine you bought and the 32 axle ***embly you dug out of the ground!
  30. hillbilly4008
    hillbilly4008
    from Rome NY
    Thanks, to be honest I'm really surprised how many parts are still in my area. Granted hot rodders are few and far between around here. If you check out my DeSoto build you'll notice that all the parts used on that car were found locally also, including the packard tail lights, old headlights, buick portholes, AND 409. Actually the guy I got the 409 from is the same guy I got the flathead and ****** from.
    http://www.jalopyjournal.com/forum/showthread.php?t=516827
    Here are the pics of the '32 Heavy axle.
    All stripped down now, ready for the drop treatment.
