I just mounted the tires for the Hudson. I want to just put the weights on the inside. NEWLY COATED WHEELS WITH WIDE WHITES. How do I get this Hunter machine set up to do that?
Select the tab that has the pictures of the weights and use the arrows to select the weight set-up you want.
I did that,Scrolled all the way over to Standard on the left. But it still does it for inner and outer.
