Hello group, I have a Hurst compe***ion plus shifter with a very rusted lever that I'd like to change out. Ive watched a couple videos about these but I cant seem to determine if the available levers are going to be correct for the changeout. John
What are you using this on? If your (rusty) shifter uses a bolt-on handle then yes as the bolt spacing is the same on all applications, it's the basic dimensions of the handle relating to your requirements that dictates which handle to get, there is even one that has more offset than the one pictured. This is hard to see the dimensions but just Google (images) "Hurst replacement shifter handles", there are lots of other photos. Here: https://www.google.com/imgres?imgurl=https://www.hanlonmotorsports.com/wp-content/uploads/2021/04/5387201_4-300x300.jpg&tbnid=aOul3tT9XhJG2M&vet=1&imgrefurl=https://www.hanlonmotorsports.com/product/hurst-shifters-compe***ion-plus-upper-stick/&docid=wBc6iElc8BVC1M&w=300&h=300&source=sh/x/im/m4/0&kgs=c908c212d6113ce9#ip=1
No, that one on Summit is a later style, you have a bayonet style. I don't know if there are new replacements for those...have fun getting it apart.
