Technical Hurst style mounts for early Olds
Discussion in 'The Hokey Ass Message Board' started by Paul, Apr 4, 2024.
  1. Paul
    Paul
    Editor
    I bought myself a little present Christmas before last, a Langmuir Crossfire Pro plasma table.
    I've been messing around with it off and on since, nothing serious, just playing around.
    I did make a few things to sell to help pay for the thing, it was reasonably priced but still a chunk of change for an old guy on a fixed income, ya know?
    one of the things that turned out ok was a few runs of motor mounts patterned off some thrashed Hurst mounts I had in the s**** pile.
    these are some pictures snapped during the process
    PXL_20230917_234535206.jpg PXL_20230929_012548669.jpg PXL_20230929_012421555.jpg
    PXL_20230929_211544285.jpg PXL_20230930_154952057.jpg PXL_20231002_191147212.jpg PXL_20240111_233256948.jpg PXL_20240112_191407993~2.jpg
    -Brent-, warbird1, RICH B and 23 others like this.
  2. silent rick
    silent rick
    you have that many projects and olds motors left in you?
  3. Paul
    Paul
    Editor
    I don't want this to come across as advertising
    just a brief show and tell of a fun little project I did out in the garage
  4. Crusty Chevy
    Crusty Chevy
    There is a need for those, they will get snapped up quickly. Now find some of the Pontiac versions and make a run of them.
  5. 73RR
    73RR
    Damn fine.
    Paul likes this.
  6. guthriesmith
    guthriesmith
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Excellent!
    Paul likes this.
  8. bchctybob
    bchctybob
    Nice work as usual Paul! I like how you use your press as a brake. I should do that to mine.
    I second the request for the Pontiac version. Maybe the Chrysler Hemi version too.
    51 mercules likes this.
  9. 37slantback
    37slantback
    @Paul I just helped a friend set one of the Longmuir CNC plasma tables last month. Kind of satisfying seeing the cutter move on it's own isn't it?
    I had thought about cutting out some Olds motor mounts because they looked like a good project to try. Looks like I was right.
    Paul likes this.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Now make some Hurst style SBC mounts that clear the mech. fuel pump;)
    HemiDeuce, skooch and Paul like this.
  11. Marty Strode
    Marty Strode
    Beautiful work Paul, you will sell those like hotcakes !
    Paul likes this.
  12. skooch
    skooch
    I could have really used these about 6 months ago!
    Paul likes this.
  13. 40FORDPU
    40FORDPU
    Nicely done!
    Paul likes this.
  14. Roothawg
    Roothawg
    How do you like the torch?
    Paul likes this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    This is the secret. It (they) goes between mount and engine block. It’s just kicked up in this photo (using mount only as a mock up support) but Hurst back in the did supply them. IMG_2623.jpeg
    skooch likes this.
  16. Paul
    Paul
    Editor
    the machine torch?
    it's good, in fact I have no complaints about any part of it.
    winduptoy likes this.
  17. Ziggster
    Ziggster
    Very nice work including the welding! As someone who has some experience coming from a company who had their own in-house manufacturing for sheet metal, I can appreciate the nesting of parts to minimize s****, and figuring out those bending lines, and allowing for the material thickness for bends. Noticed the original mounting holes appear to be all in the same plane, but the lower hole in yours in not. Just wondering why?
    warbird1 likes this.
  18. nrgwizard
    nrgwizard
    from Minn. uSA
    Iirc from mine almost 5 decades ago, the mounting holes actually should form an arc, not a straight line.
    BTW, Paul, those do look nice, For some reason, I'm remembering my set didn't allow the use of the stock pump, so electric was needed.
    Marcus...
  19. Roothawg
    Roothawg
    Good to hear. I have been reading reviews on a few and some are plagued with issues.
  20. Those are good looking parts. I hope that you so well selling them as they are needed. As someone else mentioned, do the Chrysler mounts, and then the Cadillac mounts which are very similar to the Chrysler mounts, needing only minor changes to fabricate them.
    warbird1 and Paul like this.
  21. Paul
    Paul
    Editor
    duplicating mounts for other engines would best be done by finding some original mounts and engines they are designed to fit.
    I suppose one could do it without the engine to bolt to but I'd want to verify fit before putting them to market.
    RICH B, winduptoy and tubman like this.
  22. tubman
    tubman
    I have the files for an outfit called "Send-Cut-Send" to produce the early hemi Hurst style mounts. Since I don't have my own machine, this was the best way for me to go. Two sets were less than $100 (including shipping) once I got the files. I'll give a "shout-out" to @bchctybob for providing the originals. I haven't welded them up yet (I have to drag my extra hemi out from under the stairs), but I did hot glue a set together and I'm sure they'll work. (The triangular piece sticking out inn the pictures has to be bent to fit as well.)
    winduptoy and Paul like this.
  23. Paul
    Paul
    Editor
    looks like they need holes too?
    $50.00 a set needing holes, bends and welding?
    good food for thought, thanks
  24. tubman
    tubman
    Drilling holes and welding metal together I know about and have done before. Cutting all those pieces out of different thicknesses of metal? Not so much.
    Buying such a piece of equipment is not even on the horizon at my age and situation.
    Just another way to skin a cat.:) Sorry, I forgot to say yours look excellent!
  25. 73RR
    73RR
    When I was making the Hemi mounts I had one of the local steel suppliers cut, bend and weld everything.
    They did a great job but today I'm sure the price would be alot more...7 years ago I was paying $20 per piece in batches of 50 so be sure to make enough margin to feel good about the time invested.
