Hurst Vertigate Shifter
Discussion in 'The Hokey Ass Message Board' started by Roadsir, Aug 7, 2010.
  1. Roadsir
    Roadsir
    Anyone have an instruction manual for a Hurst Vertigate Shifter? I just picked one up today along with a fresh Borg Warner Super T-10 Power Brute (Cast Iron Case) with speed shift syncros....
    WooooHoooo, this should be fun with the HEMI and QC rear.
  2. PackardV8
    PackardV8
    Yes, big fun on the strip.
    No, not big fun at all on the street
    jack vines
  3. Not so bad once the calusus develop on the two lift fingers, you just have to keep in mind on a daily driver they are like a badge of honor from ******** Gearheads! :D
  4. Roadsir
    Roadsir
    I've heard they can be tough on the street. I'll give it a shot. It's in pretty good shape. I might hit it with some brake cleaner and try some dry film lubricants on it.
    Was hoping to find an instruction set for informational purposes.
  5. DYNODANNY
    DYNODANNY
    I'm running one in my 36 ford truck. dodge hemi to a 4 speed muncie. Will see how it performs.
  6. gladeparkflyer
    gladeparkflyer
    they're not bad on the street. ran 1 for years in an old nova. lotsa fun, you just gotta be thinkin ahead on the shifts into 2nd and 1st. picked 1 up to use in my T roadster but went with a comp plus instead. the Vgate just eats up too much space. :)
  7. TR Waters
    TR Waters
    from Vermont
    The last time I checked, the instructions were still available online on the Hurst site.
  8. gladeparkflyer
    gladeparkflyer
    instructions...
    1. pull trigger up push forward... 1st gear!
    2. SLAM backwards... 2nd gear
    3. SLAM forward... 3rd gear
    4. SLAM backwrds... 4th gear...
    repeat as necessary.
    reverse.... monkey **** shifter into neutral, throw reverser.... ok, backup...
    bobwop likes this.
  9. Redz Rodz
    Redz Rodz
    flyer thats the same way i was taught to drive a buddies 69 z 28 ,a couple of 3rd gear pull outs,after that things went smooth,4.56 gear helped !!! hey i was only 16 at the time
  10. Cshabang
    Cshabang
    That sounds about right..hahaha
  11. Roadsir
    Roadsir
    They do take up a lot of space. The reverse lever is kind of hokey looking too.
  12. cruzingratiot
    cruzingratiot
    from Detroit MI
    had one in a daily for 4 or 5 years
    even had a cast on right hand with no problems
  13. Chevy55
    Chevy55
    from Nebraska
    I bought an nos one at a swap and found the breakdown online by searching with the part number on the shifter. The thing works great but will slip out of first unless you hold your hand on it all of the time and it rattles going down the road at speed. Other than that you can really spank the thing through the gears and nearly impossible to miss a shift. There used to be some brand new shift boots available through amazon for about half price. Do some online searching.
  14. Butch M
    Butch M
    I like mine real well I have had it for years...
  15. Roadsir
    Roadsir
    Thanks guys, I was checking it out a little closer last night. It may be an older version the reverse lever is round on the topside with a black ball. I'll have to look for part numbers on it.
    Everything seems to work well, but I would like the instructions to for the hell of it.
    Eric
  16. Anybody got an extra one they want to get rid of?
  17. Roadsir
    Roadsir
    There's two Hursts (one NOS) and a few Mr Gasket ones on Ebay right now.
  18. 1oldrat
    1oldrat
    I have 2 Mr Gaskets.I might let one go.I had one in my 63 fairlane when I was 18.It was great.My Dad hated it,said you need an H pattern.My mom drove it well.
  19. It does have an H pattern, just tipped on its side.
  20. Roadsir
    Roadsir
    That is a very good way to explain how they work. I sat on the garage floor (Like a kid that got a new toy) for 30 minutes playing with it and watching the mechanics.
    At least I wasn't making motor noises, or well at least nobody heard me making motor noises, I don't think I was making motor noises...but if I was and nobody heard it wouldn't be a bad thing right??:):)
  21. mattlepperd
    mattlepperd
    I got one in my stock car. I do not know why..I just did it.
    I do alot of **** that don't make sense.
  22. itsfred
    itsfred
    from Hampton Va
    if you convert the pull lever on the front to be like a hurst quarter stick it is much more street friendly.
  23. shop teacher
    shop teacher
    I have one if your still looking, Thanks, Bill
  24. 60 ford
    60 ford
    I bought one off ebay last night for my Falcon, its kinda hard to find one for a Ford toploader. I cant wait to bang some gears.
  25. Deuces
    Deuces
    Total waste of $$$ for a daily driver... I'll never do that again!...
  26. 65COMET
    65COMET
    NUROADSIR;PM with your address,I have a manual.They are a pain on the street but very useable unless you do a lot of down shifting from third gear!! ROY.
  27. SOHC427
    SOHC427
    That's the best how to I have seen!!
    I ran one for years in a Cougar Eliminator, I had as a kid. Worked great, and was fun as hell. Now I am old, and want another one!
    Eric
  28. I was just going to point that out. I converted mine to a squeeze lever and used a round knob on it. Loved it.
    Pro stock drag racers use the exact same design on the liberty (etc.) transmissions.
  29. 60 ford
    60 ford
    Thats why I bought one, in high school I had one in a Mustang now many, many, many years later it was a must have for my Falcon. Pain in the *** yes, but fun as hell.
