Technical hyd clutch
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Sep 10, 2022.
  1. Ron Brown
    Ron Brown
    installing hydraulic clutch and slave cyl in a roadster....the master cyl is 3/4" bore wilwood unit.........does the slave cylinder have to be the same bore or is it different.....my first time setting up a hyd clutch and looking for some insight.....do not want to use a hyd throw out bearing.......thanks guys
  2. krylon32
    krylon32
    from Nebraska
    With a 3/4 Wilwood master cylinder the slave should be a 7/8 bore for the proper pedal pressure.
  3. 41rodderz
    41rodderz
    from Oregon
    ^^^^ that’s the standard .
    Desoto291Hemi likes this.
  4. Texas Webb
    Texas Webb
    Glad I saw this!Thanks
