Hot Rods Hydra-matic Identification
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Jul 15, 2025.
  1. Little Wing
    Little Wing
    from Northeast
    Just Picked this up but no idea what year. 2 levers guessing 1 is p***ing gear ? Appears to be flat 12 bolt pan.
    Case.. CFD 7 8615013 350
    Tag CA-56-2056...
    Tail housing 8617399 D1
    Thought perhaps 56 but thought those were slant pan.
    bchctybob and chryslerfan55 like this.
  2. Well that’s just ducky, another shifty thread. Hehe.
    warbird1 likes this.
  3. warbird1
    warbird1
    The long outer lever on the bent shaft is the throttle valve lever. It along with the governor controls both the upshift and downshift points of the transmission including kickdown.
    My manuals are at the shop and I can check the ID tomorrow...
    chryslerfan55 and Little Wing like this.
  4. Little Wing
    Little Wing
    from Northeast
    Thank you
  5. squirrel
    56 chevy truck? is my wild *** guess.
    41 GMC K-18 likes this.
  6. d2_willys
    d2_willys
    from Kansas
    Screenshot_20250715_215300_Chrome.jpg It looks like a 1956 GMC 1/2 ton truck hydramatic. My guess it is meant to bolt up to the Pontiac 316 v8 using the Pontiac front bellhousing.
    warbird1 and Little Wing like this.
  7. Little Wing
    Little Wing
    from Northeast
    Thank you
  8. KCTA Chris
    KCTA Chris
    Fun transmissions - I have ran 2 B&M hydros and currently run a Hydro-Motive Compe***ion unit in my street coupe. On those levers - the outside is a fluid pressure needs to be set right from the start, modified transmissions put lot of force on the lever so needs really needs a mechanical linkage to the carb to work correctly. Also don't touch the two top bolts with lock nuts - they are band adjustment screws and take a special tool to set. If you can get the truck fluid coupling (18bolt?) the tourus has a little more stahl and can be modified for more. If your going behind a SBC the starter can be a real pain, the factory truck bellhousing has to use the rare truck hydro starter - I see starter cores over the $500 - Or - search for a B&M bellhosing adapter, rare part but use the more common p*** car starter.
    We had a great HYDRO group at one time with lots of good info. Another good source is "How to build your Hydro for street or strip" By Hi-rank corp, A HAMBer sells the reprint and digital files.
    302GMC and GuyW like this.
  9. warbird1
    warbird1
  10. Little Wing
    Little Wing
    from Northeast
    Awesome thank you. Does it being for truck limit the bellhousings I can use or are those universal?? Also is the pilot bearing same as standard trans ?
  11. KCTA Chris
    KCTA Chris
    Same bearing size. The trans itself is universal and should bolt to any hydro bellhousing - the truck bellhousing (plus tourus coupling and starter) are needed for mounting to a small block Chevy unless you find an early aftermarket bellhousing like a B&M.
    warbird1 and leon bee like this.
