Hydra Matic rebuild
Discussion in 'The Hokey Ass Message Board' started by YEZZI, Sep 18, 2012.
  1. YEZZI
    YEZZI
    from Arizona
    Guys I'm in need of someone who could rebuild a Hydra-Matic out of a 57 GMC near Burbank Ca. Any referrals would be appreciated. Thanks
  2. YEZZI
    YEZZI
    from Arizona
  3. Find the oldest transmission shop with the oldest technician in the area and ask them if it is something that they can do.
  4. myktrans
    myktrans
    i did one a few months ago. they are pretty simple but parts are expensive and i had to order them out of new york. the 2 bands alone are 80 bux a piece plus a core charge! crazy espensive if you ask me but i couldn't find any cheaper alternatives. i think the guy i built it for ended up spending around 800 bucks with me.
    look in your area for a mom and pop transmission shops.
  5. myktrans
    myktrans
    they are way more simple than the modern transmissions but for some reason people are scared of them.
  6. john walker
    john walker
    i rebuilt one fom my 49 cad back in '75 and it still works. that was my first automatic rebuild and it wasn't bad at all. i took it to a local trans shop that had the special band adjusting tool when i was done. be careful that they supply the proper center tube that the clutch hubs hang from. the hole for the locating dowel pin can be offset from the original, and after 1/2 an hour of driving, you lose 2 gears because the end of the tube wears off and no oil pressure gets into the clutch pack. DAMHIK
  7. myktrans
    myktrans
    does your trans have two adjusters on the top?
  8. myktrans
    myktrans
  9. 30panel
    30panel
  10. 56sedandelivery
    56sedandelivery
    Check a 'Hemmings Motor News' for a Hydro rebuilder "near" you if you don't want to tackle it yourself. The old '[Motors Manuals' are pretty specific on step-by-step rebuilds, but there are some special tools involved. Butch/56sedandelivery.
  11. d2_willys
    d2_willys
    from Kansas
    I would rebuild it, but the shipping would cost more than most of the parts. And when you say rebuild, you have to remember that some of the hard parts might need replacing too.
  12. gasserjohn
    gasserjohn
    have used parts from transmatic glendale for years&years
    they may do a rebuild for you /if they will tell you who to call
