Technical Hydramatic Banjo Rear
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Jul 14, 2025.
  1. Little Wing
    Little Wing
    from Northeast
    Anyone run hydra with a banjo tube set up ? Thinking needed to fabricate or run open drive.
    don colaps and dana barlow like this.
  2. Stan Back
    Stan Back
    This worked for me for about 25 years. Don't ask me how they did it. Changed over from an early Ford Box (39?) to a Cad Hydro. I know they shortened the Ford torque tube and the inside shaft was shortened by cutting it off, grinding the end to the inside dimension of the coupler and welded it in. The back of the Hydro was modified to take the torque tube coupler. This is it out of Ch***is #1 and installed in Ch***is #2 of 3.
  3. Little Wing
    Little Wing
    from Northeast
    Awesome thank you
  4. Bird man
    Bird man
    from Milwaukee
    Seems like 56-57 AMCs used the Hydramatic- they would have used a Torque tube also.
    bchctybob likes this.
  5. patsurf
    patsurf
    i'll bet those are RARE
    dana barlow likes this.
  6. studebakerjoe
    studebakerjoe
    I seem to recall seeing an article maybe in HotRod where they used a Buick u-joint that fit the hydramatic splines on one side and the Ford splines on the other.
  7. dana barlow
    dana barlow
    from Miami Fla.
    If ya go open drive***o_O:D:cool:, the rear bones on there own,with out Torque tube* are not strong enough,and will bend with any real HP n bite.= The torque tube was/is the strong part. So add bracing to rear bones. if open drive....
    Little Wing likes this.
