Technical Hydramatic Fluid
Discussion in 'The Hokey Ass Message Board' started by Fender1325, Nov 8, 2014.
  1. Fender1325
    Fender1325
    Hey guys,
    My caddy shop manual is at a friends house whos not available at the moment.
    Im about to change the trans fluid in my 50 cadillac hydramatic.
    Does anyone know how many quarts ill need?
    Also, the modern dexron ATF is reverse compatible with previous dexron generations right? For example a V would be safe to use in a car that called for II. Correct?
    Im draining the whole thing and dropping the pan as well, so Im not trying to mix any fluid.
    Thanks
  2. 550Coupe
    550Coupe
    I beleive it's around 10 - 11 qts. I used Ford type F fluid. It will give you a more positive shift.
  3. Fender1325
    Fender1325
    Thanks.
    Would you guys believe I called 6 different cadillac service departments across 2 states just to ask if modern dexron works with previous generation dexron.
    Not a SINGLE one picked up the phone. They all had a lady to transfer me to the department but not a single person picked up. How do they do business!
  4. a 30 second Google search netted this
    Dexron VI—the newest GM ATF, it was developed specifically for the new six-speed automatic and is a synthetic blend (meaning it has some conventional base stocks). That transmission has tighter internal tolerances and required a fluid that had higher shear strength that Dexron III.
    It was introduced with the 2006 models. GM considers Dexron VI to be "backward compatible," meaning GM recommends it for use in any vehicle that originally used any earlier version of Dexron and that it can be mixed with them
    Do you really think that a Caddy dealer is going to know anything about a 65 year old car?
  5. Fender1325
    Fender1325
    Yeah. I went to the dealer and got a nice older service tech who took me back and searched his computer for service bulletins that talked about the backward compatibility of modern dexron. He couldnt find anything but ***umed it would be okay.
  6. Fender1325
    Fender1325
    Called a shop in California that specializes in hydromatic rebuilds and I was told the Dexron VI would work fine.
  7. saltflats
    saltflats
    from Missouri
    You will have to drain the converter to change all the fluid.
  8. Fender1325
    Fender1325
    Did that - thanks :)
  9. blue57ford
    blue57ford
    If you still have questions about the capacity measure what you drain out and then refill to within a half quart of what you measured, just to ensure that you don't overfill the transmission. Then check your level and add if needed. Also I would go with Ford Type F fluid. Using a semi synthetic or full synthetic fluid in older transmissions might make it prone to seal leaks.
  10. 302GMC
    302GMC
    from Idaho
    I remember old guys putting a couple teas****s of brake fluid in with the new stuff - it softened the seals enough to help cut down seepage. Don't know if I'd try it today ... and I damn sure wouldn't pour Ford fluid into it.
  11. Fender1325
    Fender1325
    Well Im pleased to say the cadillac took well to the dexron VI. Shifts were nice and smooth. I dropped the pan and cleaned the filter and pan, new gasket. Adjusted the linkage some more and it down shifts from 4-3 now.
  12. dan griffin
    dan griffin
    Old hydros used rings ( like little piston rings) for seals. I don"t think brake fluid would do much for a steel ring. Tell me again why type F is not good in a hydro. I ran type F in my Olds and it would spin the slicks on the 2-3 shift.
  13. Fender1325
    Fender1325
    I am by no means a transmission expert, but I think I read type F fluid has more "grip" to it. Id be afraid itd be too much for the components of a 64 year old transmission.
  14. 30panel
    30panel
    I also use Type F in my Hydro flat plan, shift's as hard as you want or you can adjust the tv with a veneer cable
    55 Pontiac hydo is a tank.
