Hot Rods Hydramatic tools
Discussion in 'The Hokey Ass Message Board' started by Jim the Sweep, Jun 14, 2021.
  1. Jim the Sweep
    Jim the Sweep
    Hello again from Britain,
    has anyone got advice about band setting tools for a 49 hydramatic?
    The trans is out of the car on a stand. My shop manual shows a couple of special tools needed to set it up.
    Can you get round this in true hotrodder fashion?
    Anyone made up tools from bolts/tube etc.
    Failing that it is grovel around under a running car in drive which strikes me as...hazardous?
    Thanks,
    Jim
  2. pvfjr
    pvfjr
    Hi Jim, there's a Hydramatic private forum that you might want to join. Lemme see if I can find the link...
    banjeaux bob likes this.
  3. pvfjr
    pvfjr
    canman and banjeaux bob like this.
  4. Jim the Sweep
    Jim the Sweep
    pvfjr likes this.
  5. warbird1
    warbird1
    It's best to use the correct tools to adjust the bands on a Hydro; though it can be done without them it's pretty sketchy and may or may not work. I'd be looking on ebay for tools...
    Jim the Sweep likes this.
  6. willys36
    willys36
    I adjusted the bands on my '54 Hydro using the 'count the turns' method 25 years ago and it has shifted very smoothly, even the 2-3 shift, all these years. But it has the two adjusting screws on the top, I think the early boxes only had one?
  7. bchctybob
    bchctybob
    Look for the thread “Mild Custom ‘51 Pontiac Chieftain” posted by PhilA. He wrote a detailed description of his adventures with his hydro. He may have some info in there on how he did the band adjustments. If nothing else, it is a great read on what’s inside and how to rebuild one.
    Jim the Sweep and pvfjr like this.
  8. justpassinthru
    justpassinthru
    Google Hydramatic band adjustment. I think even Fatsco has the procedure on their site.
    There is method of adjusting them while running, that works well, but the trans has to have both external adjusters, and accessible through the floor to do.
    I build enough early Hydros , that I have the tools to adjust. The procedure running, is time consuming, and time is money.
    Also later Dual Range Hydramatics have the front band adjuster internal, so the running procedure will not work for that model.
    You could probably make the rear band tool, if you had another one to copy from, but the front band tool is specialized, and would not be able to reproduce.
    There are both tools for sale on E-Bay right now, the rear band one is not too expensive, but the front band one can get pricey.
    The tools were made by Kent Moore, Bonney, New Britain and Snap On, that I know of.
    I have a New Britain rear tool, that I think I paid 45.00 for, and a Snap On front tool that I got lucky and paid 100.00 for.
    Good luck with the project.
    Bill
