Hydramatin Flywheel ID
Discussion in 'The Hokey Ass Message Board' started by ljs05, May 11, 2011.
  1. ljs05
    ljs05
    OK, I just got a flywheel and torus for an early (55-59) Hydramatic. The guy I got it from swears he unbolted it right off the back of a 265 Chevy V8. This is the second one I got like this. But it will not bolt up to any Chevy small block crank I have. It has a smaller center hole and the bolt pattern diameter for mounting it is smaller also. It has 6 bolt holes and 3 dowel pin holes. Any one know if there ever was a small block v8 with a different pattern? Or what's up with this?
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    SBC cranks were the same on the rear flange from 1955-86. Have you held it up to a 235 crank?
  3. Dirty Old Nash
    Dirty Old Nash
    The small block chevy hydramatic flywheel is smaller than all others. The standard Olds-Pontiac-Cadillac etc had 145 teeth and was about 14.5" diameter. If yours is that size it's not for an SBC. I think the chevy was 139 teeth but I'm not sure.
  4. If the 265 had a TURBOGLIDE trans then it will have a different flange on the crank and will not interchange. (very rare). I have been working on vehicles for over 40 years and have only seen one (1), and I owned it......garage car.
  5. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Turboglide engines required a special pilot bearing if converting to standard shift, but the bolt pattern was the same.
  6. d2_willys
    d2_willys
    from Kansas
    That is correct!
    Turboglides, IIRC were introduced in 283 equipped Chevys in 57. Sure this was the last year of the 265 in a Chevy car, but I believe Turboglides needed all the power/torque they could get. They were never used behind 235's either.
