Technical hydraulic clutch bracket help
Discussion in 'The Hokey Ass Message Board' started by Pridesman, Jul 8, 2023.
  1. Pridesman
    Pridesman
    from Texas
    Hello
    I have a steel chevy bell housing#
    GM11 3925505
    I need a hydraulic clutch slave bracket for my slave cylinder...
    the aluminum brackets don't work as the bolt holes will not line up
    Does anyone have a bracket or can u point me to bracket that will work for this make bellhousing...I don't need the whole kit..just the bracket
    Thanks for the help!
  2. lumpy 63
    lumpy 63
    Try Novac conversions, they have some nice hydraulic clutch parts but I'm not sure it will work with your existing slave because you didn't post any pics. Also make sure your bellhousing has the correct input register size for the trans you are using as some truck housings have a bigger register size than passenger car transmissions .
  3. lumpy 63
    lumpy 63
    If you can locate a 60-62 chevy 1/2 ton V8 bell , they have a factory hyd. clutch set up with the fork on the passenger side that work very well on cars with space limitations.
  4. Bob Lowry
    Bob Lowry
    lumpy 63 likes this.
  5. RICH B
    RICH B
    Easy to make, if you can't find one.
    lumpy 63 and Truckdoctor Andy like this.
  6. hepme
    hepme
    I used one of these on a 40 chevy coupe with hyd. clutch. It was a push, not pull, type. Used an S10 slave, homemade rod and bracket (sorry, no pix). Advice: used grade 8 for rod if you have one, and the bracket should be no less than 3/8" and bolted super firm. Huge pressure on these components.
  7. bobss396
    bobss396
