Technical hydraulic clutch conversion for Ford
Discussion in 'Traditional Hot Rods' started by Douglas Smith, Mar 2, 2023.
  1. Douglas Smith
    Douglas Smith
    Does anyone make a hydraulic clutch conversion kit for the late 40s, early 50s Ford/Mercury 3 speed transmission?
  2. jcrapola
    jcrapola
    I expect you can piece one together with some simple measuring. I spoke with Howe racing and McLeod for help on my hydraulic throw out bearing setup, and they both made it super easy to understand what matters when selecting parts. Of course, my setup (SBC and a T5) is far more common, but I did not buy a kit to do it. I selected parts based on the info I got from the tech support guys, and it was not too bad. I am still setting up the pedals on mine. But it really isnt too bad. PLus I saved about $100 by figuring out the parts list instead of buying a kit.
  3. BamaMav
    BamaMav
    from Berry, AL
    Wouldn’t be too hard to set up a master/external slave set up, lots of vehicles used them. Could probably use factory parts with some home made brackets. Lots of aftermarket cylinders and masters out there, too. I adapted an OT import truck system to a Chevy Saginaw 4 speed many moons ago, all I had to do was make a new bracket and a longer pushrod. It worked as well on the Saginaw as it had on the original application.
    Hombre, bobss396 and Desoto291Hemi like this.
  4. bobss396
    bobss396
    Someone here was making and selling kits that looked good. I believe it was a pull-type slave. On my car, I used a Speedway push slave, 7/8" and a Wilwood 3/4" master and an AFCO 32" hose. I located the slave to the side of the bell housing, master up on the firewall.
  5. Jmountainjr
    Jmountainjr
    It's a pretty easy thing to do. First take a look at the room you have to work with and decide if you want a push cylinder or a pull cylinder to move the linkage. Then fab up a bracket to mount the cylinder that will pick up two bell housing bolts. Check that the cylinder has the needed amount of throw and match it to a correct master cylinder. Lately a lot of guys are using the Mustang cable release instead of hydraulic. Might want to check that out.
  6. krylon32
    krylon32
    from Nebraska
    I've fabricated several over the years for customer cars. All of mine used a lever and push arrangement.
    Desoto291Hemi likes this.
  7. oj
    oj
    Tilton makes an adjustable Hydraulic T-O bearing, I'm getting ready to fit one into my '41 toploader, I have to machine the candlestick for the bearing and I think you have the same candlestick. I have the same cross-shaft exiting my transmission and it made for difficult geometry to connect the slave cylinder, it had too much freeplay with the stock T-O bearing and I didn't have enough room for pedal travel is why I went looking for the adjustable hydraulic T-O bearing. I have the slave cyl, a master cylinder and a clevis that'll bolt to the trans cross-shaft if you want to go that route or I can let you know how the hydraulic T-O unit works.
    The hydraulic T-O is salty.
  8. gimpyshotrods
    gimpyshotrods
    I won't any longer use a clutch slave cylinder that is inside the bellhousing.
    I have seen too many fail. That can juice the clutch, making it necessary to replace it.
    External solutions don't require removing the engine or transmissions to replace them if they fail.
    Oddly enough, of all of the external ones that I have installed, not a single one has failed.
    egads, seb fontana, Bleach and 8 others like this.
  9. Jmountainjr
    Jmountainjr
    I agree that an external setup is easier to R&R if needed. But I have also used hydraulic TOBs with success. In some applications a hydraulic TOB just solves some fitment issues. I have also investigated several TOB failures of differing brands on friend's cars. In no particular order, the typical issues that contributed to the failures:
    1. Not installing a pedal stop to prevent over stroking the TOB piston.
    2. Not selecting the correct TOB for the application. Race clutches typically need less stroke than a street clutch and there are TOBs for each.
    3. Not using the recommended master cylinder bore diameter for the TOB used.
    4. Not doing the initial clearance setup correctly.
    Beanscoot and Desoto291Hemi like this.
  10. hemihotrod66
    hemihotrod66
    The only issue I have with my hydraulic TO is it is always in contact with the clutch levers..It has no return spring in it or no way to install one...It means the TO bearing is always turning....I guess this would be true with new cars that have the same setups....
    seb fontana and deathrowdave like this.
  11. deathrowdave
    deathrowdave
    from NKy
    TO bearing spinning all the time and no way to lube it . I think about it daily on my OT ***mins Powered , Power Wagon . That is one double pain in the *** to replace a TO bearing in , also . You will probably never see the extremes in temps that the Ole Power Wagon sees , but temps ., seriously change the hydraulic advantage also . I know what your sayin “ he is nuts “ , but it does .
  12. el Scotto
    el Scotto
    from Tracy, CA
    Hydraulic setup on top loader.
    Your ****** will take the earlier transmission ('32-'39) clutch shaft and arm.
    Then you can adapt a slave cylinder to it much easier.
  13. gimpyshotrods
    gimpyshotrods
    This^.
    seb fontana and little howard like this.
  14. dave agosti
    dave agosti
    seb fontana likes this.
  15. dave agosti
    dave agosti
    I second on the HYD. TO bearing. Remote easier to replace on the road.
  16. little howard
    little howard
    from kcmo
    Do you know what magazine, and month and date, this article came out in. I'd like to try and buy it,
    Thanks,
    Howard
    alanp561 likes this.
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    maybe I missed it but what kind of car is it in? is there a reason not to use good old ultra reliable mechanical linkage?
    gimpyshotrods likes this.
  18. Mike Lawless
    Mike Lawless
    I went with the Tilton hydraulic throwout bearing along with a Wilwood master to go on my T5 trans swap. I put the pedal on ball bearing pivots, mounted the master under the cab and used the stock actuating rod from the pedal to a bell-crank I made that mounts to the ch***is where the stock Z-bar attached.
    The goal was smooth and easy pedal action. That goal was achieved.
    As for longevity....we shall see. As for the bearing always turnings...Maybe. The way they are supposed to work is that the clutch fingers skim the surface of the TO bearing without turning it much. I haven't poked my head in there to see for myself though.
    Every method of clutch actuation has its merits and disadvantages. I've had both types of hydraulic slaves in my OT drag car, as well as the stock cable. Both have been reliable.
    jimmy six likes this.
  19. Words of wisdom. In my time at the Rod Shop we bailed out a couple rodders on road trips when their internal setups failed. Even with a lift and an entire shop both events turned into major PIAs for folks that were on vacation hoping to hit a rod run instead of wrenching on their cars
    egads and Nailhead Jason like this.
  20. birdman1
    birdman1
    i just go to o'reilys and get the master cylinder and slave cylinder for a 1959 or so ford truck. easy to mount and cast iron tough.
    anthony myrick and Tman like this.
  21. Bleach
    Bleach
    Another vote against a hydraulic TO. I had one in a OT, a 4X4. It had a habit of leaking out mysteriously without any trace of fluid dripping. It caused me to destroy the 1st gear synchros.
    I could drive it for months at a time without problems but every now and then the reservoir would drain out somehow. I didn’t want to pull the transmission and transfer case to replace it. I just checked the reservoir every trip I made and kept a bottle of fluid in the cab.
    Got rid of that POS a few years back. Good riddance. Never buying anything with one of TO’s ever again.
  22. Douglas Smith
    Douglas Smith
    Checked O'Rielly's site and the '59 set up is not listed.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
  24. Douglas Smith
    Douglas Smith
    Moriarity likes this.
  25. el Scotto
    el Scotto
    from Tracy, CA
    Shows for me
  26. Moriarity
    Moriarity
    SUPER MODERATOR
    man, that master cyl is only 25 bucks on Rockauto
    el Scotto likes this.
  27. el Scotto
    el Scotto
    from Tracy, CA
    Oh I love RockAuto. They're my go to for most things I can plan, although I still price check between them and the local guys. :cool:
  28. Beanscoot
    Beanscoot
    Yes, but the enslaved cylinder is $58!
  29. Moriarity
    Moriarity
    SUPER MODERATOR
  30. Douglas Smith
    Douglas Smith
    Ok, I've decided to (try) install a hydraulic clutch setup in my project car. As mentioned above the transmission is a '51 Ford F1 3 speed mated to a '51 303 Olds. Does anyone make a TO hydraulic bearing for the '51 Ford Transmission (10 spline, input shaft diam.) Or am I limited to an outside slave cylinder? If so, any recommendations for make/model?
