Technical Hydraulic Jack Fluid
Discussion in 'The Hokey Ass Message Board' started by blowby, Dec 23, 2019.
  1. blowby
    blowby
    from Nicasio Ca
    OK, dumb question of the week maybe. Can I use ATF or brake fluid in a bottle jack? Don't feel like driving into town but I will rather than hurt the jack.
  2. oldiron 440
    oldiron 440
    I put something other than hydraulic fluid in a new jack one time and the jack went to ****. Now ATF type F is nothing but hydraulic fluid with red dye in it so there might be a chance that it will be ok?
  3. Budget36
    Budget36
    I put ATF in an old one of mine, been working a long time w/o issue. I figured we used to use ATF for power steering fluid.
  4. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    I have used hydraulic brake fluid....
  5. Beanscoot
    Beanscoot
    I would think any oil of similar viscosity will be fine, but definitely not brake fluid - it's a different family of fluid (it's water soluble, even). Brake fluid will not mix with the remaining oil, and of course absorbs moisture from the air, promoting rust.
    So it will work in a pinch, but is bad for the longevity of your jack.
    ClayMart and Boneyard51 like this.
  6. Boneyard51
    Boneyard51
    Yep, most anything but brake fluid. Engine oil works good, too. What happens most of the time is, when you have to add fluid to a Jack, it means it has developed a leak. So the seals are already damaged. So they are on their way out any way, no matter what fluid you put in it. That’s why people blame a certain fluid as causing damage to their Jack. But sometimes you can buy some time!
    Bones
  7. oldcootnco
    oldcootnco
    I had good luck with power steering fluid.
