Hot Rods Hydraulic lifter test oil.
Discussion in 'The Hokey Ass Message Board' started by rtp, Apr 19, 2020.
  1. rtp
    rtp
    Any of you guys interested in a gallon of hydraulic lifter test oil ,with original box.
    Seriously found way in the back of the shop .no idea where it came from or how old it is . 0419201631_HDR.jpeg 0419201628_HDR.jpeg
    Sent from my VS987 using The H.A.M.B. mobile app
    loudbang and Budget36 like this.
  2. BJR
    BJR
    Just put it in the cabinet with the blinker fluid.
    loudbang and Texas Webb like this.
  3. Joe H
    Joe H
    Dad use to have a lifter tester, it was really old. It had a big old weight out on an arm, I suspect you put a lifter under it somehow that was filled with your oil, then you checked for leak down or something. The oil was probably a standard so all lifters would check the same way.
    Deuces likes this.
  4. rtp
    rtp
    I knew someone would have an idea what it as for.
    I have never heard of checking lifters like that . But that makes sense.
    Thank you
    Sent from my 100005207 using The H.A.M.B. mobile app
    Deuces likes this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    Wasn't Kent- Moore the company that made the majority of the special tools for dealerships ??
    Hnstray likes this.
  6. 57 Fargo
    57 Fargo
    We still have them at our college, if I was allowed in our shop there I would take pictures.
    Boneyard51 likes this.
  7. 302GMC
    302GMC
    from Idaho
    In the days when hydraulics were new to most makes, factory shop manuals had directions covering repairs. This is the test fluid used after the job is done.
  8. Boneyard51
    Boneyard51
    This kinda goes with a post I posted a little while ago. If a lifter has a measurable leak down, that is acceptable, how come you don’t hear several lifters clatter on an engine at start up? Several lifter will have spring pressure on them ant any given point the engine stops. So after it sets , say for a couple of days, how come you don’t hear a lifter clatter? But if you adjust a lifter by screwing down the rocker, it will correct itself in less that a minute?
    Bones
  9. They are AI lifters. (Artificial intelligence).
