Hydraulic shock question
Discussion in 'The Hokey Ass Message Board' started by DaSandman, Jun 23, 2013.
  1. DaSandman
    DaSandman
    Does anyone know if you can change the stiffness of a hydraulic shock by changing the weight of the oil?
  2. hron13
    hron13
    from sandy eggo
    you could if you could find a way to drain and fill it. Make sure you use a fluid that wont foam if you manage to pull this off, like motorcycle fork oil, or hydraulic fluid.
  3. Hot Rod Grampa
    Hot Rod Grampa
    High performance racing shock absorbers are made to be fine tuned. Changing the viscocity of the fluid is only one of the variables. Most off the shelf stuff in an auto parts store is not in this price category. If you need stiffer to control bounce, consider a shock from a heavier vehicle, but remember the shock absorber is also designed to hold suspension within specific travel limits. Too long a front shock and the coil spring can pop out of the socket when jacked up, just a note to keep in mind.
  4. ev88f
    ev88f
    To soften a shock you can drill it and add sewing machine oil. This is something most commonly done with manx buggys so thesamba should have more info on it.
  5. Zerk
    Zerk
    I've heard of lever arm shocks on older British cars getting a heavier oil for stronger damping. I'd say it could work on tube shocks, but cutting into a shock that might be gas-charged would be a hazard, and sealing a regular hydraulic shock after draining and refilling would be an interesting problem.
  6. HVSpeed
    HVSpeed
    Are you trying to make the shock softer or stiffer?
  7. FrozenMerc
    FrozenMerc
    As already mentioned, shock oil is one of many variables that can change both rebound and compression rates on a shock. However, you can only change it if the shock is rebuildable, and most welded tube automotive shocks are not. You will also need a way to recharge the nitrogen (up to 400 psi) in the shock after changing the oil. Below is a picture of rebuildable Elka shocks. These are not cheap and normally racers are the only ones who spend the cash on shocks of this type.
  8. plym_46
    plym_46
    from central NY
    used to put half mc fork oil and half stp in the lever action shocks of the AH bugeye sprite I used for auto crossing. Its all about how quickly the damping fluid can p*** through the metering orifices and whether you want to control the motion equally in both directions. So you can diddle with the viscosity or you can can change the valving hole size. Or you could just buy some of those Koni, or Tokikos
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yes, on certain shocks. When I swapped a 289 Ford into my Austin Healey Sprite years ago I put in 90 wt gear oil to handle the extra front end weight. It helped a lot.
    Don
