Technical Hydraulic Throwout Zephyr Trans
Discussion in 'Traditional Hot Rods' started by Piewagn, Oct 27, 2020.
  1. Piewagn
    Piewagn
    Has anyone ever used, or know of a hydraulic throwout bearing that will work with a 39 Zephyr trans?
    Thanks for any and all input fellas!
  2. birdman1
    birdman1
    First measure the diameter of the tube the throw out bearing rides on. Then find a hydraulic release throw out bearing from speedway in lincoln. Then have the tube machined down to fit the bearing. I'm talking about racing parts now. Call speedway and tell them what you want to do
  3. Piewagn
    Piewagn
    Thanks for the info birdman!
  4. hemihotrod66
    hemihotrod66
    Mcleod clutches make them to....You might check with them...Used them on my 34 Ford with a Dodge 4 gear ******...
  5. alchemy
    alchemy
    Wouldn't you rather use an external cylinder so you aren't burying your potential leaks inside the bellhousing?
  6. Bandit Billy
    Bandit Billy
    Oh but Alchemy, the internal ones are much more fun when they need servicing! Add sarcastic roll eyes and made up tag :rolleyes: #neveragain
    TrailerTrashToo and warbird1 like this.
  7. Piewagn
    Piewagn
    Not mine....just researching options for a customer that’s got space issues and previous work from someone else....
    I’m trying to convince him to go with the F1 crossmember and pedal ***embly, but he doesn’t want to cut out the crossmember someone else installed....
    Personally, if I have to, I’d prefer the external.....but it’s his call.....
    Thanks for everyone’s input!
