Technical HYDRO-POWER BRAKE BOOSTER
Discussion in 'Traditional Customs' started by 1959Buick, Feb 21, 2023.
  1. 1959Buick
    1959Buick
    from BC Canada
    I do not know if I can post this on HAMB. I HOPE SO
    At the moment I feel like living in the 80's in a East European Country. If you need something all you hear is AT THE MOMENT NOT AVAILABLE OR CHEAP MADE IN CHINA STUFF.
    On my 1976 Eldorado the HYDRO-POWER BRAKE BOOSTER is leaking and also the master cylinder. I wonder if I can replaced the old HYDRO-POWER BRAKE BOOSTER with a new HYDRO-POWER BRAKE BOOSTER out of a 2011 -2022 Chevy or GMC Truck.
    I know many in this group here know more about this stuff than I know
    Thanks Herbert
  2. 47chevycoupe
    47chevycoupe
    from Finland
    The 76 should have flare fittings and the later boosters have o-ring fittings. The way the brake pedal rod attaches is different but probably could be adapted to work. The plate that mounts to the firewall should swap over to the later booster.
  3. 1959Buick
    1959Buick
    from BC Canada
    Thank you , I know they make Adapter fitting for the o-ring fittings. So this should be no problem
  4. 1959Buick
    1959Buick
    from BC Canada
    What about different strokes and pressure requirements?
  5. egads
    egads
  6. 1959Buick
    1959Buick
    from BC Canada
  7. egads
    egads
    From their website---
    So, before you call and ask it if fits your car or truck I can stop you right there and say YES it fits. Does it fit my Ford Truck.... YES.....Does it fit my Dodge.....YES....Does it....ok wait i told you that it fits ALL hydro-boost Bendix units.
  8. 1959Buick
    1959Buick
    from BC Canada
    Thank you. I saw they also have a video how to repair the Hydro
  9. gimpyshotrods
    gimpyshotrods
    I run Metric-era one in my Falcon.
    The pushrod is different.
    The early, pre-Metric ones have a removable pushrod. The Metric-era ones don't.
    Other than that being a potential issue, they work the same.
    ***ist pressure is based on your power steering pump.
  10. 1959Buick
    1959Buick
    from BC Canada
    Thank you , good to know
