Technical Hydroboost warning for builders
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Jun 15, 2020.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    Boneyard51 likes this.
  2. Boneyard51
    Boneyard51
    Yes, the pump would have to have the ability to produces at least that much pressure. A pump, by itself, does not produce pressure. The flow of the pump has to be restricted! The amount of restrictions and capacity of the pump determines the pressure and flow ,ie GPM.
    Not sure what you are referring to as a “can” .
    Bones
    anthony myrick likes this.
  3. 2OLD2FAST
    2OLD2FAST
    from illinois
    Ac***ulator canister
  4. Ok.
    I guess another factor for mine steering well is the skinny, 14 ply 8R tires
  5. nosford
    nosford
    If anyone is interested this is the tool that was used to test pressure/flow from the Dodge Ram service manual. OTC is the high quality version but there are lesser cost versions if you look around. https://www.otctools.com/products/heavy-duty-power-steering-pump-****yzer
