I am looking for some whatchamacallits
Discussion in 'The Hokey Ass Message Board' started by oldolds, Dec 7, 2010.
  1. oldolds
    oldolds
    I am looking for some br*** inserts that are knurled on the outside and are threaded on the inside. I had some from a friend that worked at a casting plant. But the place no longer makes the same stuff and he cannot remember where they got them. If I at least knew what to call them I could look them up. Local industrial supply only has kids at the counter, they need a name.
  2. thendrix
    thendrix
    Check Mcmaster Carr. If they ain't got it, you don't want it.
  3. Slag Kustom
    Slag Kustom
    look at threaded insert on mcmaster carr
  4. da34guy
    da34guy
    Yer lookin 4 "Nutserts"
  5. boldventure
    boldventure
  6. He is not looking for Nutsert's
    These are the ones I use, for my casting of molded parts. can be used in Laminated FRP Parts, during the layup of the parts.
    ( fibergl*** reinforced parts)
    http://www.yardleyproducts.com/
    You can order online
    [​IMG][​IMG]
  7. Eight433
    Eight433
    I've bought em from home depot or lowes before but I think it was more of a barb than a knurl
  8. oldolds
    oldolds
    Thanks, Divco.
    I should have said not nutserts.
    Mcmaster Carr is great if you know what you are looking for.
    I find that asking a friend sometimes gets you a better answer.
  9. Da Tinman
    Da Tinman
    Search Mcmaster for threaded inserts. There are several styles, press fit, mold in etc.
  10. The pics look like what Ford 4.6 intake uses if you are going to mold them in I probably have some I saved out of old intake for some reason ? ill look Larry
  11. bobss396
    bobss396
    You want Dodge (not the car maker..) Ultraserts. Go to the Helicoil site (Emhart Fastening Systems Group) and they should have them. I have a catalog in my hand, PM me if you need something looked up.
    Bob
  12. Chris Stapley
    Chris Stapley
    Clearly not whatchamacallits, these are thingamajigs! Sorry, couldn't help myself. Looks like some of the good folks on here have helped already, I'm just here to try and make you chuckle this time.
  13. 64 DODGE 440
    64 DODGE 440
    from so cal
    Used to attach gizmos to the whatchamacallits.:p
  14. oldspert
    oldspert
    from Texas
    I thought they were Hoochie Mommas
  15. I thought they were referred to as dooflickies???
  16. GaryB
    GaryB
    from Reno,nv
    the best ones are the chingadaras
