Technical i beam alignment question
Discussion in 'Traditional Hot Rods' started by wick22, Nov 5, 2017.
  1. wick22
    wick22
    I have a 57 chevy truck and the wheelbase is 1/2in shorter on p*** side and I looked and I beam is a 1/2in back on rf
    is there sometimes two alignment holes on top of I beam and the wrong hole got used or is this normal?
  2. RMR&C
    RMR&C
    from NW Montana
    No. Axle is slightly bent on one end.......but it can be fixed.
  3. Charlie Jones
    Charlie Jones
    from Apopka FL.
    A good TRUCK alignment shop should have the equipment to bend the axle back where it belongs .
  4. Joe H
    Joe H
    It could have sheered the center pin on the leaf springs from a pot hole hit something similar. Take the weight off the front and loosen the u-bolts to see if the pin is still there.
    Another possibility is the spring is installed backwards and the center pin just happens to be offset.
    Mr48chev likes this.
  5. sunbeam
    sunbeam
    Look at the shackles are they at the same angle?
  6. wick22
    wick22
    pulled rf leaf spring apart and leaf spring pin is shaped like a lightning bolt lol...kinda S shaped
  7. Mr48chev
    That should be a big part of your problem. I'd think reworking both springs at this time would be a good idea.
  8. wick22
    wick22
    I planned on replacing leaf spring pins in both sides,u bolts,shackles and leaf spring bushings
  9. rusty rocket
    rusty rocket
    Sounds like you have a project now. I would think the U bolts would not have to be replaced unless they are bent or the threads are chewed up.
