I been framed
Discussion in 'The Hokey Ass Message Board' started by old chevy nut, Dec 6, 2010.
  1. old chevy nut
    old chevy nut
    from va
    hey guys, just staring on a 37 chevy pickup project, I am going full fenderd kind of 70,s look. my question is whats a good frame to use thats close to my pickup, original was 112 in wb is a car frame useable? thanks for any advice
  2. mj40's
    mj40's
    38 Chevy car is 112" wheel base. What's wrong in using your pickup frame?
  3. Kevinsrodshop
    Kevinsrodshop
  4. THE_DUDE
    THE_DUDE
    Ot for sure man but dare I say Toyota, or Mazda. IF yer frame is not useable.
    I have done it with a few frameless cars
  5. rottenrods
    rottenrods
  6. EnglishBob
    EnglishBob
    Stock frame with MII and coilovers.
    S10 4 x4 rear end sits in nicely.
  7. tubman
    tubman
  8. mj40's
    mj40's
    112” wheel base is only one measurement to consider. Just remember not all late model frames will fit the width of your fenders. Nothing worse than spending a bunch of bucks and finding that your fenders won't bolt on because the tires won't clear the fenders when turning.
  9. Kevinsrodshop
    Kevinsrodshop
    Hmm good point! i didn't even notice his screen name. ***umed he meant 37 Ford truck. You know what happens when you ***ume.
  10. junkman8888
    junkman8888
    Greetings! My '38 cab was from a one-ton truck, found out pickup frames of that vintage are hard to find so I didn't know what I was going to do until one day I threw the cab up on a 48-54 pickup frame just to keep it off of the ground and found out the cab would fit if I swapped the body mounts, Hope this helps, Mike.
  11. old chevy nut
    old chevy nut
    from va
    dont have a frame, starting with a rust free cab and 2 bed sides
  12. old chevy nut
    old chevy nut
    from va
    sorry guys its a 37 chevy pickup
  13. dubcee
    dubcee
    s-10 did a 40 with one and it was cheap and easy!
  14. lowmater_tn
    lowmater_tn
    you could use a s-10 frame and the Original frame is the same on these
    ford car 35-40
    ford truck 35-41
  15. KJSR
    KJSR
    from Utah
    I have a frame (36 chev) that will fit it, PM me if interested...
  16. BOWTIE BROWN
    BOWTIE BROWN
    here are the numbers for my 40 chevy pickup.
    overall lenght=166
    wheelbase=113 1/2
    width in rear =40
    width in front=28
    all are for stock fenders and grille, iam sure you can find something close to home .
    good luck & keep it posted.
    ART MORRISON.COM
  17. kisam
    kisam
  18. oldcarfan
    oldcarfan
    from missouri
  19. Deuces
    Deuces
    :eek::eek:
  20. gsp392
    gsp392
    You know with fuzzy dice, **** carpet dash cover, curb feelers etc..:eek:
  21. toms37gmc
    toms37gmc
    Not on Chevys, car and pickup frames are completely different (car is a "top hat with a plate on the underside, pickups are a C channel. They are also different widths. I have seen a couple 37 Chev PUs on S10s that turned out real well.
