Projects I bought a 55 chev pickup!
Discussion in 'The Hokey Ass Message Board' started by yule16met, Nov 17, 2008.
  1. yule16met
    yule16met
    from Hudson, WI
    no, I like chopped trucks but Ive never seen one of these chopped and look good to me. I like them kinda tall. The girlfriend has already named the thing the SHARK truck because of the grill. She even googles whale shark for me to see the resemblance.
  2. recardo
    recardo
    from Winslow
    Mines a big window, and people tell me that's where the name red-neck came from. After driving a few hours you are sun burned to hell :p
  3. fortynut
    fortynut
    I've owned a couple of that body style. Put five lugs on the first by changing to '53-54 Chevy p***enger front drums, and '57 Chevy car rearend to up the ratio and get five lugs so I could use 15" recaps. Back in the day 16's were hard to get, and ****. I ran the 265 w/ split manifold and gl*** packs. It was milage getter. Drove it back and forth to CA from MS in the 60's --- you can only imagine the Rockies after being in SF. Second was '57 big back window that I clipped with a '79 Firebird front end to get disc brakes and power steering. I drive my stuff. The latter one I changed the rear springs by cutting rivets out of 73-80 pu hangers and using the better/later springs and found a 57 Ford 9" at Long Beach Swap Meet. I ran 8"Vette rallies on the back and 5" rallies on the front.You can drill the frame and bolt the reat spring hangers on. A ***** but it's low tech. Be sure to use grade 8 bolts. The '57 has a 350 4blt w/ 350 turbo. I sold it to my brother and he still drives it. These babys are like iron. Welcome to the brotherhood. I'm, now, in the process of scrounging parts for a third one. It's a habit. I have a 292 and a 5speed stashed for it. Forget body mods. These are like dueces. God was looking over the designer's shoulders when they were doodling the lines. Not a bad angle, if you like pick-ups. Just make yourself a driver out of it and wail.
  4. recardo
    recardo
    from Winslow
    I'd say that a chop is out (ugly), but a roof pan-cake would be an interesting look (kill the cone-head) :)
  5. ibcalaveras
    ibcalaveras
    Yours looks much better than mine did when I bought mine. I clipped it, then got rid of the old drive train. It was a lot of work but well worth it in the end....
  6. yule16met
    yule16met
    from Hudson, WI
    I found a set of doors for 100 a piece and a set of fibergl*** fenders for 200. So all togeather I would have 600 init and just floor pannels and corners to buy.
  7. I used the front seat from a 55 Chev. It had to be raised up to the proper height, but the width was perfect. It is much more comfortable than the original seat.
    Bob
  8. yule16met
    yule16met
    from Hudson, WI
    You mean a 55 chev car? I think I could find one of those easy enough.
    I got the doors and found out the guy had 3 camaro subframes out back!! So I now have 5 doors total and a camaro subframe sitting next to the truck.
    I NEED FRONT FENDERS!!!!! ANYONE?
  9. swade41
    swade41
    from Buffalo,NY
    You should strive to make it into this..lol
      57.8 KB
  10. yule16met
    yule16met
    from Hudson, WI
    If it was a different color, it wouldnt be half bad. I like the pro street look on these trucks. Not so much the chop though.
  11. swade41
    swade41
    from Buffalo,NY
    That thing acutaly ran low 5's in the 1/8 mi. but I never understood the pink paint, it was all fibergl*** including the cab, bed everything.
  12. bensimmons_05
    bensimmons_05
    from Weaver, AL
    I did not get a chance to read through all the threads but... cl***icperform.com has been a life saver for me. I work at a parts store so I would buy what I could from there and get the rest of the brackets/ adapters and everything I had to from cl***ic performance customs.
  13. 5w32
    5w32
    mine is a 55 cameo , dodge dakota clip is a good front end ( call industrial ch***is for crossmember) .....i have a some photos of the ch***is build , chevy van tilt column, 4 bar rear , 57 olds rear end , 57 suburban gas tank, 427, th400
