I cant find these f#*%$@g BOLTS- UPDATE
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Apr 14, 2011.
  1. Deuces
    Deuces
    Is that anywhere near Fort St.??? Could be the old building... I've p***ed that place up before.. Many moons ago..
  2. Deuces
    Deuces
    How about these guys??? www.smallparts.com Ya never know.. You just might get lucky.. :D
  3. 1950Effie
    1950Effie
    from no where
    Let me get that info for you today. Back to you tonight.
  4. Bigchuck
    Bigchuck
    from Austin, TX
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yep , but on the back side of the Marathon Refinery
    I think the name of the street is Oakman
  6. jimvette59
    jimvette59
    If you can find some thing close in stainless you can whittle it down with a file and a drill held in a vice or hold it in a drill press, then polish it. Just a thought.
  7. Here's the pic of a similar bolt on my '07 HD bagger. Rear bag protector to frame behind a cover.
    Comments about my dirty motorcycle are off topic lol.
    Head of bolt is just peaking out on the right of the chrome bar.
    I can't tell what size it is without dismantling the bike and Harley shop isn't waking up for another hour.
  8. after u wash yours. would u kindly come over and do mine
  9. gasser
    gasser
    Couldn't you use repro early V8 door hinge screws which have the narrow head and stamped csk washer. The ones I am thinking about are 32 coupe..
    We use the bolts you pictured in work, on retail displays but I am on the wrong side of the atlantic...
  10. Deuces
    Deuces
    I know where Oakman is... I'm just a few blocks west from there in Dearborn but farther north near Ford Rd. I used to be a tow truck driver in the early '80's around that part of the neighborhood.... Scary!! :eek:
  11. Thanks. However that is not the technical, or proper name of the bolts being pictured.
    pan head machine screws are different.
    That avitar is great!
  12. Nice job divco,
    Thanks for helping and showing those are an option but they are different and would require some modification to use them.
    How freaking hard can it be to get a bolt?
  13. Just got off the phone with acme nut and bolt.
    He new exactly what I wanted but said I'd have trouble finding them. They don't have them.
  14. Searched Aaron's last week, don't Have them
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    yeah the guy is good,
    Bummer he cant get em for ya..If i run across "smokie" (the dude that sells bolts the down river area companies I'll ask him.., I'll also see if i can hunt him down this morning..
    so what is the "real name" or should i still use "cheese head"...lol:D
    and wash that bike:D
    now i know where ive seen that type of bolt before..I have a 97 HD..They probably order them special..cant score some from HD?
  16. Dennis D
    Dennis D
    I haven't read the whole thread so you may have stated the size before. Crown forklifts use them. I just ran across a couple of different sizes in the drawer I was looking for something else in. Give me a size and I will see if I can come up with a part number. Dennis D
  17. As you can see they exist. & right under our ****s in some cases
    And as You can see the proper name is as illusive as the bolts.
    "Cheese head" brings images of that head style however a slot drive.
    Got a bit of info from a few places that say terminology is extremely loose in the fasteners world. Hence the photographs of bolts. One Guy I spoke to this am said they were called "special low head torx" only available in metric and 6x20 mm was the largest available. So that's not the name either
    Harley has that bolt listed as a "1/4-20 knurled head torx " But it certainly isn't knurled head by definition or like any other I've ever seen. They had to call it something but didn't know either so made one up. Searching that brings up thumb screws.
  18. 5/16 24 x 1 stainless is preferred but I don't know about that at this point.
    metric would be 8x25 mm
    7/8 is the absolute minimum amount of thread.
  19. Mr48chev
  20. Dennis D
    Dennis D
    These are 18 thread not 24. Let me email my contact at the Crown factory and see if I can find out where they source them. I'll get back to ya. Dennis D
    Got an "out of office reply" I won't be able to find out anything until Monday. D
  21. M_S
    M_S
    from SoCal
    I found mine (if these look the same) at the local Ace/True Value. It's been a while since I did that, but I think they were longer, had to be cut and tapped up to the head (had a shoulder) for my application. I was more worried about the head design.
    They are in the hardware section under "furniture fasteners".
    PM me if you still have trouble finding them.
  22. The specs on "low head" 5/16 bolts.
    Bolt diameter 0.3125 or 5/16
    Head diameter 0.437 or 7/16
    Actual clamping surface of that bolt is ( .437-.3125 ) or 0.1245 or. 062 per side
    7/16-5/16 = 2/16. 1/16 for each side . Seems kind of useless doesn't it and why low heads wont work.
    Maybe the specs are incorrect, but every site that had specs had the same data.
    Can any body verify this with an actual measurement of a part in hand.
  23. Ill buzz the local ace and give them a visual ( vice grip hardness check)
    thanks .
  24. 18 thread would work just fine.
    Thanks for checking. :cool:
  25. indyjps
    indyjps
    They look like hardware that comes with bolt together pressboard furniture.
  26. rosco gordy
    rosco gordy
    Those look like forign body bolts check with any dealer body shop guys ya know I used to save that **** all the time, cause we could not even get it from the factory those are specialy bolts gw and alike will look at ya like your from mars if ya askem just a sugestion from a cheap old rodder
  27. Bump for actual hands on measurements
  28. jonahboo
    jonahboo
    from NJ
  29. Dennis D
    Dennis D
    I measure 9/16 on the bolt head on the ones that I have. 7/8" long. Crown part number is 120544-002. I know you have a dealer nearby, hopefully they will have them in stock for you to look at. Dennis D
