Technical I caught the Banger virus
Discussion in 'Traditional Hot Rods' started by Manager, Dec 31, 2014.
  1. Rocky
    Rocky
    Classified Editor
    That's a good lookin sports coupe. I think I'd finish up the rear spring and remove the landau bars if it was mine. Hell, I might even go nuts and paint the wheels yellow to match the paint too but that's just a personal choice for me....I hate red wheels on anything. I'd be proud to drive that little coupe.
    kidcampbell71 likes this.
  2. Well said!
    Fair enough!:D
  3. Russ B
    Russ B
    Looks great, nice enough stance, but you could drop it a bit more in the rear with no harm to clearances. My '29 cabriolet is now very close to the same stance as yours, but I am going to try to get just a bit more drop on mine once the body is off for paint. Tubular shocks work fine and were becoming common by the sixties. Your landau irons should be swapped left to right to get them on the right sides. In northern CA, 16" Red wires were the norm in the early sixties for Model A's. Looks good to me. I have had sbc Model A's, but am enjoying my cabriolet with its four banger as much as anything.
  4. Binger
    Binger
    from wyoming
    Great looking car. Always glad to have another banger guy on board.
  5. Nice looking car,but watch out!!! Once you get one banger they start breeding when your not home:D
    kiwijeff and 530sandman like this.
  6. What he said X2!:D
  7. But the banger babies always start out as needy little infants! $$$
  8. 4BangerDean
    4BangerDean
    I have to admit I like driving my A with the banger in it. It's surprisingly fun. I can see why you've got the fever. There's a lot to like. I probably would have built mine up if a seller and I could have agreed on a price for some speed parts he had.
  9. Ron Brown
    Ron Brown
    Hey...welcome to the banger club. way to much fun. may not be as fast as a SBC but boy do the bangers catch peoples eye. lotta fun
    Tiny likes this.
  10. Manager
    Manager
    Thanks for your comments. Shocks are next on the list. Going to the local coffee run Suday morning, been a few times but will be first time lowered. Oohh what was that? You could be right, another case off the virus.I feel a roadster minus fenders coming on.;)
  11. X38
    X38
    I will see your car there. If it's not raining.
  12. Manager
    Manager
    Just went for a quick run now and the weather is ****. Windy as **** and showering. Will have to be pouring for me not to go this week.:)
  13. Watch out that's how it happens. Next thing you know your buying estates from widows:eek:and filling sheds with cast iron!!:D
  14. Manager
    Manager
    Been a while since I did anything other than drive this thing. Decieded yesterday to put the front shocks on and reverse the spring and clean it up while I was at it. I made the brackets and bought the shocks ages ago. Everything clears and nothing hits so a good result. Had too leave a ****** out off one side of the shackles as it hit the shock but thats a minor. I bought a pair of hot rod type shackles but didn't realise A's are 11/16 pin and spring eye and hot rod stuff is all 3/4 so the stockers with the ****** out will do for now. Next week the rear goes down , i can get about 1 1/4 " and put the shocks on. lower front 001.jpg lower front 002.jpg
  15. dwollam
    dwollam
    Did you have to use longer (the threaded part) spring perches to put the lower shock mounts on?
  16. Manager
    Manager
    lower front.jpg Funny you should ask that. I used the stock ones which are a bit short so I tried to buy5/8 unf half nyloc nuts and couldn't get any so i got normal ones and cut about 1/4'" of them so the nylock got on to the thread. I had a2"x 5/8 unf bolt and nut laying around so I locked the nylock nut on it 1/8" inch and cut it off on the saw. Here is a pic of what's left after the cut so you can get what i'm saying.
    Jeff34 likes this.
  17. dwollam
    dwollam
    So that is a new available lower shock mount and you just made a thinner nylock to hold it on? That sounds doable!
    Thanks,
    Dave
  18. waxhead
    waxhead
    from West Oz
    Looks good with the front lowered. What are your plans for lowering the rear??
  19. Manager
    Manager
  20. Manager
    Manager
    It's already about 3" lower than stock. I rearched the spring a bit like the shape of a T spring last time. Going to rearch a bit more and reverse eyes.
  21. dwollam
    dwollam
    Cool, thanks! I have a set of lower mounts like that already.
  22. Manager
    Manager
    I found Posies have the hot rod type shackles for 11/16 eyes. Page 8 of their catalouge.
  23. bangerbob
    bangerbob
  24. bangerbob
    bangerbob
    My Banger above
  25. Manager
    Manager
    Got the rear shocks on a couple of weeks ago, just havn't got around to posting it. The top mount bolts down through the bumper iron holes and 2 bolts through the side of the crossmember. The spacer can be removed and the irons can go back on if I decide I need bumpers. Also bent some repro pickup tailight brackets and installed a second light and wired indicators. Probably shift the number plate to cover the spare wheel bracket holes. Didn't get to the spring, had to go to a couple of local runs. Next week.:rolleyes: mod plate 002.jpg back shocks 002.jpg mod plate 003.jpg mod plate 001.jpg
    waxhead likes this.
  26. 97
    97
    NO, won't happen .... "Banger Virus .... No Known Cure"
  27. Manager
    Manager
    Flash lower rear 007.jpg Finally got to the rear spring. Reversed it and a bit more changing the arch and got the eyes rolled a little to shorten it slightly as the shackle angle was getting too steep. Even fixed the handbrake.:eek:
    Latigo, waxhead, 120mm and 2 others like this.
  28. Looks great
  29. V-8 isn't that bad, a little tobacco, a touch of Worcestershire, and a healthy does of Vodka is the perfect remedy on Saturday morning. ;)
    I actually knew a chick with the "banger" virus. I quit visiting her.
    Reminds me of a jingle:
    Hey there swingin' bachelors
    Are you tired of the steady drip
    Drip, drip of Gonorrhea?
    Then Peter Rooter's for you
    Peter Rooter, that's the name
    You just flush your troubles
    Down the drain
    Rotten Peter, rotten Peter, rotten Peter [Cheech n Chong]
    OK foolishness aside, I got a lot of repect for the banger crowd. it takes a lot of patience and perseverance for a man to wring the ponies out of a banger and you got to respect that. looks like a good choice for a totally trad build.
  30. modelAsteve
    modelAsteve
    BANGER VIRUS- Had it for 60+ years. Tried lots of cures-Nothing works- Stopped looking for a cure and decieded to just enjoy it!
    SEE YOU AT THE FAST AUBURN HILL CLIMB THIS COMING SATURDAY!!!!!!!!!!!!!!!!
