I couldn't wait..my 32 chassis pics inside
Discussion in 'The Hokey Ass Message Board' started by Grumpy, Mar 26, 2006.
  1. Grumpy
    Grumpy
    from NE Ohio
    I wanted to wait to post pics until I cleaned it up, and got the ugly rollers off the back, and got the front clamped into a more ride height look, plus put my spindles and F100 brakes on, but.....I couldn't wait any more..
    I'll be the first to admit that I cannot build/weld chassis', and I admire those that can. And with that in mind, I had another HAMBer build it for me.
    "what fenders" aka Dave Macan, from Oberlin Ohio built it for me. I am happy as can be with the qaulity of work. Him and his partner/uncle are great people.
    They're actually starting on another chassis for another HAMBer. But I'll let them do the talking about that.
    I also want to Thank Rolf, Clark, and woody for answering alot of questions for me.
    Here's a quick rundown.
    ASC rails, they step-boxed in that So-*** fashion
    slight pinch for 31 Model A
    Hand-built Model A style front crossmember, flattened and moved forward 2in for a 108 wheelbase
    8in rear with a 40 front spring, bobbed rear rails
    The rear is a parallel 4-bar type set-up using heavily modified 38 rear bones on the bottom and modern up top.
    Plus the rear spring hangers are heavily machined/modified 38 units. Those are the ones normally attached to the axle tube..not anymore!
    The front is 40 split bones, 4in dropped ibeam, c-notched
    There's no steering box mount because I'm going cowl steering
    I don't know, there's more, but my brain is numb right now.
    Anyway, here's some terrible pics. I hope to move it outside this week to take better pics.
    Thanks for looking
  2. Very nice, Grump....your 31 body will look deee-luxe, sitting on it.
  3. Grumpy
    Grumpy
    from NE Ohio
    Thanks Rock
    Here's a couple more pics.
  4. Rolf
    Rolf
    Looks great Grumpy...
    I do like the step boxed solution, makes a nice inner edge...
    Almost a roller :)
    Keep us in the loop !
  5. Ryan
    Ryan
    ADMINISTRATOR
    Awesome... love the front bone placement...
  6. Sweet man. I have a weekness for all things 32 anyway. i have a new frame in the works also.
    Your frame looks great, all 32 chassis done well are like artwork. Yours is no exception.
  7. woody
    woody
    Very nice. A great milestone to get a "roller". I do like the way you did the rear bones as well as the fronts.
    Woody
  8. The37Kid
    The37Kid
    Very nice!Looks like it will sit nice & low, that head light bar is a nice piece of work too.
  9. Grumpy
    Grumpy
    from NE Ohio
    Thanks guys.
    The idea was I wanted to mimic the Rollin Bones kinda look, with a Model A twist. Sorta, but not really, but kinda.....
    I wanted it lower than a normal 32, but not nut dragging.
    I knew I wanted it just low enough that the front bones would attach to the rails, not below them, and it was Dave's idea to build the 4bar rear deal using bones for the lowers.
    Thanks again
  10. 48fordnut
    48fordnut
    Excellent choice for the use of the folks you did use. creative individuals. good work.:D
  11. Dirty2
    Dirty2
    Looking good. I like where the bones are also,
  12. UPSrodder
    UPSrodder
    Looks Great!!!, Let me know if you still want to borrow the engine and tri-power for set up and break in. Talk to ya later. Dennis
  13. Deuce Roadster
    Deuce Roadster
    Looks real nice.....
    I also like the fact that the transmission crossmember unbolts. So many do not......so then it is a PIA when transmission time comes......
    Sounds like " you have the PLAN..."
  14. Rusty
    Rusty
    Very nice progress!!
  15. triplexkustoms
    triplexkustoms
    it looks even nicer in person. i had to go over and drool on it for a couple of hours.
  16. fab32
    fab32
    A very tidy looking chassis. Be sure to keep us posted on the rest of the build.
    Frank
  17. burger
    burger
    Tim,
    Congrats! I'm glad this is finally happening for you. Good luck with the rest of the build.
    Ed
  18. Roothawg
    Roothawg
    People don't realize how much work it takes to get to that point. Nice job.
  19. Grumpy
    Grumpy
    from NE Ohio
    You're right. And all I did was give input and drive 93 miles each way many, many times. Dave and Bob did all the work.
    I have my bearings and seals coming for my F100 hubs. Everything for the brakes is sandblasted. I got new studs..My kingpins are done, so waiting on bearings etc, and I can get the front a roller.
    I have my 72 ford truck steering box all cleaned up, so now I have to reverse it and it'll be close to ready for when the time comes.
    I'm running 16x4.5 and 16x6 steelies and Firestones. He set the chassis up based on those tires, and said it should be at 3 degrees.
    Thanks again. I'm very excited. Like a little kid at Christmas:eek: :D
  20. very nice work..i like how a wishbone was used as a lower bar of the rear 4-bar
  21. haring
    haring
    That must be very exciting to now have a complete chassis. Enjoy.
