Technical I.D. BBC engine
Discussion in 'The Hokey Ass Message Board' started by miller, Dec 27, 2024.
  1. miller
    miller
    from New Jersey
    Hi, IMG_6890.JPG IMG_6898.JPG see attached pics is this a tall deck or the short deck thanks in advance
  2. Fordors
    Fordors
    Short deck, here’s a photo for comparison.
    427 sleeper, SS327, big duece and 2 others like this.
  3. PackardV8
    PackardV8
    If buying a tall deck, know your specs. Recently, a would-be Hamburger proudly dragged one in. When shredded, it was 3.937" bore, a 366"; just very expensive anchor material.
    jack vines
  4. miller
    miller
    from New Jersey
    Thanks for the pics. So, the pics I have sent in are from a short deck is that correct? Thanks again
  5. 69fury
    69fury
    from Topeka
  6. miller
    miller
    from New Jersey
    once again thanks to all for the info. Miller
  7. Budget36
    Budget36
    Also. Did the tall deck have “high perf p***enger” cast in it as well?
  8. miller
    miller
    from New Jersey
    I am led to believe the pics I sent in are for a SHORT deck. I do see "perf p***enger" but not "high". Look at the 1st pic I posted, below the cam on the driver side of the block you will see the " perf p***enger" words. ...Question I do have a short deck YES?
  9. TRAVLR
    TRAVLR
    366T and 427T tall deck blocks have "TRUCK" cast in the block. I've never seen Hi performance p***enger cast in the tall deck blocks.
    Budget36 likes this.
  10. TRAVLR
    TRAVLR
    Yes... You have a short deck block.
  11. miller
    miller
    from New Jersey
    Thank You I started to get lost there Thanks to all again for the info as always great info Miller
  12. Budget36
    Budget36
    Sorry, added the “high” myself I guess.
    But are you looking for a tall deck BBC?
  13. squirrel
    The words cast into the ends of the block don't mean much, they just tell the guys making the castings, which castings use that particular mold for the end of the block. There are some molds that are used on all 3 types of blocks: p***, truck, hi perf. So you'll find blocks that say all three things, and it tells you nothing about what block it actually is.
    But if you look at other features of the block, you can tell what it is. 2 bolt mains usually is P***, short deck 4 bolt is usually HI PERF, and tall deck is usually TRUCK.
    mad mikey and Truckdoctor Andy like this.
  14. miller
    miller
    from New Jersey
    NO I was wondering what block I have thanks Miller
  15. squirrel
    All we can tell from that picture is that it's a short deck Mark IV block. If you can take a few more pictures, or find numbers and post them, we might could tell you more, if you're interested.
    look for numbers stamped on top of the block, just in front of the p*** side head. Look for numbers cast on the top of the bellhousing area, behind the heads. There should be a few different sets. Also there might be some small cast numbers/letter above the oil pan rail, on the driver side, middle or rear of the engine.
  16. Eric David Bru
    Eric David Bru
    from Iowa
    Post the numbers Squirrel mentioned and we can tell you exactly, but it is for sure a standard 9.800" deck, not a tall deck.
    EDB
  17. miller
    miller
    from New Jersey
    Thanks, I will in a few days try to see what numbers I can find and then I will post them Miller
  18. big duece
    big duece
    from kansas
    Does the crank damper have a external counter weight?
  19. miller
    miller
    from New Jersey
    I found the following numbers... on the block drivers side front, where the head meets the block 27776....on the block d/s in the rear where the trans bolts to the block I found 14015445..the 2nd number appears to be a 4 however it is hard to see and maybe a 1??? thanks miller
  20. snoc653
    snoc653
    from Iowa
    It’s a 78-90 454 out of a truck or motor home.
    squirrel likes this.
  21. squirrel
    Since it's a late Mark IV block, the engine number could be stamped on the little pad just above the timing cover. I just remembered....that's where it is on my XCH, which is from 1989.
    this is where the numbers are on it...
    Engine number, above timing cover
    This is the engine number. I think it means
    T - Tonawanda engine plant
    L - ?
    22 - 22nd day of the month
    XCH - suffix code
    9 - last digit of year
    On the back, driver side:
    This is the block casting number
    On the back, p*** side, near the middle: xch3.jpg
    This is the casting date. F is the 6th month, June, 16th day of the month, 9 is the last digit of the year, in this case 1989.
    Look for these numbers on your block. I think this late in the Mark IV production run, the 454s were all 4 bolt main, used in the SS half ton, and 3/4 and 1 ton trucks and motorhomes, and sold over the counter. They were selling a lot of LS-6 and LS-7 engines at that time. The one I have is an LS-7.
    lumpy 63, 427 sleeper and Budget36 like this.
  22. miller
    miller
    from New Jersey
    Thanks for the info and location of the numbers I will take a closer look Miller
  23. big duece
    big duece
    from kansas
    Pull a valve cover and get a casting number too, if it's rectangular port it should have a little mark on the end on oval_port_cast_line.jpg square_port_cast_line.jpg the heads. Don't see it on yours.
  24. miller
    miller
    from New Jersey
    Hi I found the numbers on back p***enger side of the block A 24 8. and on top of the timing area 0131UBH what do I have? miller
  25. squirrel
    Suffix code UBH is a 1983 Truck 454, 3/4 or 1 ton, 210 HP. It must have been used on something else as well, because your casting date is Jan 24, 1988 and the engine ***embly date is Jan 31. Unless you misread the last digit of the date casting, and it's really 3, not 8
    Finding a complete list of suffix codes for truck engines is pretty difficult...sorry
  26. miller
    miller
    from New Jersey
    It is very likely I misread the # 8 and it is a #3 thanks for the help and info Miller
    big duece likes this.
