Hot Rods I.d. Hood
Discussion in 'The Hokey Ass Message Board' started by VSO737, Feb 17, 2012.
  1. VSO737
    VSO737
    Confirming that this is a MODEL A hood................
    and if so, CAN YOU TELL ME WHAT YEAR IT IS ??
    Thank you in advance,
    Mike
    [​IMG][​IMG][​IMG]
  2. No bead would make it an early hood (28-29).
  3. VSO737
    VSO737
    WOW............thanks Michael for the quick response.
    I guess my next question is:
    ¿ARE THE "EARLY" AND "LATE" MODEL A HOODS INTERCHANGEABLE??
    Thanks,
    Mike
  4. SquireDon
    SquireDon
    from Oregon
    Rockne hood????
    Edit: No, can't be. The louvers are not at a slant.
    1932 Studebaker???
  5. alchemy
    alchemy
    Not a Ford hood of any year.
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Im with alchemy..Not a Ford car hood..
    the louvers are an insert or at least look like they are (not the same type of louvers for a ford)..the hold downs are too high up on the side..and what ever that thing is on the inside isnt ford
  7. VSO737
    VSO737
    PICTURE WITH THE DIMENSIONS........................
    THE AREA OF THE LOUVERS IS PRESSED and NOT WELDED IN.
  8. Can I be the 3rd to confirm that it's not a Ford hood?
  9. I 'm thinking a late 20's Dodge with a length like that most likely had a 6 cylinder under it . Rob.
  10. Ned Ludd
    Ned Ludd
    No, they're not. The size and shape of both the firewalls and the grille shells differ between early and late. Moreover early hoods slope down to the radiator cap more sharply than the late ones.
  11. VSO737
    VSO737
    Thanks WOODY 29 DODGE................
    As far as I can tell, it goes to a 1924 Dodge and maybe others in that era.
    Thanks to all.......................
    LG,
    Mike
  12. 32STUPRES
    32STUPRES
    Not a 32 Stude hood!! They have 36 louvers on EACH side and will dwarf any Model A hood...Joe
  13. Hell, I have a '32 Rockne hood, I knew it wasn't that.
    Also, that's a quote in my signature, not my name.
