Technical I.D please
Discussion in 'The Hokey Ass Message Board' started by Drylake, Jul 27, 2017.
  1. Drylake
    Drylake
    Are these rims chev? Particularly the artillery rim. The stud pattern is 4.25 centre to centre. [​IMG]I may not be looking in the right places but I've had a little trouble finding and artillery with the same number of ribs. Thanks in advance for any help.
    Sent from my SM-N910G using The H.A.M.B. mobile app
  2. Sancho
    Sancho
    Look like 1936 Chrysler artillery wheel.
  3. 302GMC
    302GMC
    from Idaho
    Looking at the clips, the top one is an orphan, Hudson or ? The clips on all the '48- '54 Mopar wheels I have are facing outward in two bends ... 2nd is a '34-5 Mopar. They're a 4.5" pattern, not 4.25", & we call them wheels here.
    Tell us what you're trying to find - we'll help.
  4. TagMan
    TagMan
    Not meaning to start anything - just an observation: 'Rims' and 'wheels' are pretty much interchangeable terms, at least they have been in my neck of the woods for the last 55+-years I've been playing with cars.
    Budget36 likes this.
  5. LOL the meaning is implied and understood. But in every pecan tree you'll find a peckerwood who is looking for a mate. :D
    Around here the people in the neighborhood got it figured out, they call 'em wheelrins, best of both worlds. :rolleyes:
    kiwijeff and BobbyRay like this.
  6. Everybody should know what a "wheel" is,. the term, "rim", can be misunderstood by some. Especially with old stuff and trucks.
  7. Drylake
    Drylake
    Doesn't the photo help, wheel/rim. The stud pattern isn't 4.5" it is 4.25".
  8. Los_Control
    Los_Control
    from TX
    measuring the bolt pattern is from the outer edge of one hole to the center of hole across from it.
    So I agree that center to center is 4.25, it actually is a 4 1/2" bolt pattern. And the top rim looks just like the wheels on my 49 and 52 dodge trucks and the 52 plymouth wagon. no idea what the second rim in photo is.
    Mopars had locating pins on the brake drums, then used bolts. The smaller holes inbetween the lug bolt holes is for the locating pins on the mopars.
  9. Squablow
    Squablow
    First one looks like 48-54 Dodge/Plymouth 15" wheel and the artillery looks like a '36 Plymouth wheel to me.
    Definitely measure from center of one to outside of an opposing lug hole, those are 4.5" pattern wheels. Center to center measurement won't give a true diameter of the bolt pattern circle unless the wheel has an even number of lugs (works for 4 and 6 lug wheels, not 5 lug) Imagine a circle that intersected the center of each lug hole, now draw a line between two lugs, center to center. It doesn't split the circle in half, it's offset. That's why you measure to the outside of one of the lugs, to make up for that offset.
    drylakespeedshop likes this.
  10. Drylake
    Drylake
    Thanks for the help in identifying them, they're both 16".
  11. Squablow
    Squablow
    If the first one takes a 16" tire then it's most likely a 47-earlier Dodge/Plymouth/Chrysler wheel.
  12. Drylake
    Drylake
  13. 28 Ford PU
    28 Ford PU
    from Upstate NY
  14. WiredSpider
    WiredSpider
    It,s funny that you are giving him **** for his spelling of tyre(which is correct for England,Australia etc) but you can,t spell Ghetto
    LWEL9226, Hnstray, kiwijeff and 2 others like this.
  15. Drylake
    Drylake
    Ok... tyre is correct spelling (au). One spaz exits... another enters...
  16. chopped f1
    chopped f1
    from Australia
    might change name of hamb ot hasb hokey *** spelling board !
    and yes in Australia we spell it tyre!
    i wont even enter the rim/wheel debate i think we all knew what drylakes was asking about
  17. Los_Control
    Los_Control
    from TX
    Many were 16", the 1949 in my avatar is actually a 3/4 ton truck, it came with 15" 5 on 5" bolt pattern. While the 1/2 ton trucks and 52 plymouth suburban came with 16" wheels with 5 on 4.5" bolt pattern ... 16" is perfectly normal back then.Actually the 49 in my avatar has a 1/2 ton front axle on it with 16" wheels.
    I pulled my truck sideways a couple inches in soft dirt to make a tight corner parking it.
    My wheel cracked inbetween the bolt holes (marked in red) I no longer trust any of the wheels and will junk all 12 of them, install modern wheels for daily drivers.
    And measuring (marked in black) from outside edge across to center hole, will give you your true bolt pattern spacing.
    drylakespeedshop and chopped f1 like this.
  18. In New Zealand, we also spell it, tyre.
    When I'm on here, I spell it tire, just because.....
    When in Rome.;)
    Sorry, I can't help with ID.
