Technical I.D. this Booty
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Jun 9, 2017.
  1. clunker
    clunker
    from Boston MA
    I think someone already got it, right? You dropped a big time hint in the ***le of the thread. I knew already, so I didn't have to guess (funner to let people try to guess.)
  2. sunbeam
    sunbeam
    The engines on a stand. Used to set up engines like that to sell even a stock 2 barrel 283 will really rip with just a flexplate.
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    JLO
    chryslerfan55 and Johnny Gee like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Some one did give two names and one was correct but the only acknowledgment I gave them was a like to it. The ***le of this thread "was" a deception to draw readers in first and for most. Now let's move on. After the back side of the engine in question received a proper I.D. I felt I owed those that were disappointed by this thread not being what they thought it was. So I found something to entertain everyone's fascination with the female backside and it worked. Are you saying you knew from this "What Actress/Entertainer does this Booty belong to ?" on reply #16 is how you knew already ?
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Flathead Dave is correct.
  6. DDDenny
    What was the question ?
    Johnny Gee likes this.
  7. Slopok
    Slopok
    She sure has a weird right thumb!o_O
    theHIGHLANDER likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Your a normal male. :cool: :)
    Your not a normal male. :confused: ;)
  9. Enough with this Nashcan hack.
    #2:
  10. farna
    farna
    Looks like someone made a test stand, and cut the flexplate out so they could see things like that rear freeze plug (seals end of cam bore). The First generation AMC V-8s (AMC was formed in 1954, V-8s were first made in late 1956) are internally balanced, so the light flexplate wouldn't hurt. I wouldn't run it that way in a car, but should be okay if all it's doing is turning the engine with the starter.
    You don't have to tear it down to change the rear seal. It uses a rope seal, typical of all engines in the 50s. Neoprene seals didn't come out until the 60s. Ideally you take the crank out to change the seal, but it CAN be done without pulling the crank. More likely to have leaks that way though, best to remove the crank to change a rope seal in ANY rope seal engine.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    On post #16, can you give us the year that first came out and why the flywheel is so much different ?
  12. clunker
    clunker
    from Boston MA
    I knew it was JLo, (had seen images of that performance), but would rather it had been Charo (with lots of "cootchy-cootchy"), and it reminded me of watching tv in the 70's, where she seemed to pop up everywhere. Or even Brett Somers, I'm kind of JLo'ed out at this point.
    (Supposedly), God (ya the big guy himself), through divine intervention, gave George Romney and his special underwear, (not sure if a lizard delivered the information or not), a V8 for Nash/Hudson in 1956 (250 ci), then in '57 a 327 ci. The '57 Rambler Rebel w/327 was only beaten in 0-60 mph Motor Trend trials (domestic production cars) by Corvette w/ fuel-injected 283. It was a light car with a pretty powerful motor. That would be a cool car to find these days. I wonder if anyone can id the year of that AMC motor in the pic.
  13. sunbeam
    sunbeam
    I don't think that is a pre 66 booty.
  14. Barn Find
    Barn Find
    from Missouri
    Is the fact that the 225 hp Nash Fireball was also a popular marine engine provide any clue? It doesn't really explain the hacked flexplate, but it could have had a marine bellhousing they considered to be useless, so they kept only the the part needed to hold the starter.
    Here's what they look like in my 1958 Chris Craft
    [​IMG] [​IMG] [​IMG]
    chryslerfan55 and Asphalt Angel like this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
  16. I tend to think it's a Studabaker V8
