Technical I.D. Windshield frame.
Discussion in 'The Hokey Ass Message Board' started by 392, Aug 6, 2019.
  1. 392
    392
    06D4965A-2937-4804-956E-A811B0D6549D.jpeg D6DBBD01-106B-47A4-BAE6-BFE8F1B1E751.jpeg 54D6E77D-0C69-46B7-B684-7EAB188E82AD.jpeg 1FE0D1D9-C5F5-4D18-B574-7A2B300F6368.jpeg 93D5B78B-275F-4FD7-A8B4-B2B67081B5B9.jpeg 140B483A-D160-4524-8184-6B7D07F56149.jpeg Looking for what this could have been on.
  2. Nailhead Jason
    Nailhead Jason
    An Austin maybe? its mighty narrow
  3. goldmountain
    goldmountain
    I just went and measured my Austin Ruby and it is 4" narrower than that one. Looks very similar however.
  4. Speed Gems
    Speed Gems
    International Truck?
  5. Gerrys
    Gerrys
    could be used as a sunroof
  6. 392
    392
    Yeah I was thinking international but no good dimensions on web I’ve found. Thanks goldmountain for checking your ride.
  7. The37Kid
    The37Kid
    Has a Ford look to it, check Anglia, and other Fords built overseas. Bob
  8. 392
    392
    392
    Possible Willy’s ?
  10. jazz1
    jazz1
    814EE561-6721-4DBE-B664-6CC17871AFCA.jpeg it does resemble International frame however too short and the hinges are wrong. This International frame is 15”
    It would be a close fit for this IHC cab I chopped down 3”
    Speed Gems likes this.
  11. Speed Gems
    Speed Gems
    '36 Ford (car) or mid 40's Dodge or Chevy p/u is the only other thing i can think of.
  12. jazz1
    jazz1
    The frame is only 11” tall. Not much comes to mind on this side of pond. Maybe ‘30 Dodge?
  13. Gerrys
    Gerrys
    Cuved or Flat? If curved gl*** it would be early 50's or newer.
  14. TagMan
    TagMan
    I found some measurements of a '36 Ford car windshield I had taken for a friend. The width at the widest point was 42-3/8" at the widest point. The height was 13-7/8" tall in the center. Both measurements were from the inside of the window frame with the gl*** installed.
    The subject windshield of this post is definitely not a '36 Ford, at least not one made in the USA. The joint between the upper & lower halves looks exactly like the Ford, but the hinges are completely different.
  15. KevKo
    KevKo
    from Motown
    I don't know about measurements, but the shape looks like '33 Willys.
