History I finally understand why Studebaker went out of business...
Discussion in 'The Hokey Ass Message Board' started by yorgatron, Nov 9, 2008.
  1. yorgatron
    yorgatron
    they were JUNK!!!:mad::mad::mad:
    stupid 3-on-the-tree doesn't work,and don't tell me to adjust the goddamn linkage,it's fucked up inside the column.
    and i know it's a wagon,but it goes around corners on the doorhandles,and wallows up and down and back and forth and pitches and yaws like a sailboat with a broken keel.
    don't forget the understeer,the way this thing plows into a corner it should be painted green and built by John Deere.
    here's another thing,why is the engine so heavy? :confused:
    it's only 259 cubic inches,but it weighs over 700lbs.
    the Cadillac engine they stole this design from was 331 c.i.d.
    i'm gonna stick to Hudson from now on :(
  2. Elvisaurusrex
    Elvisaurusrex
    Them's fightin' words!
    I'm a Ford man myself though..
    Hey, at-least it wasn't Chinese made, it's a genuine American made POS! Look at the bright side.
  3. See if the "Lemon Law" applies and have Studebaker replace that car!!!
  4. stude_trucks
    stude_trucks
    Sounds like you're having a good night George. Keep a happy face.
  5. atomickustom
    atomickustom
    You just described practically every car made prior to 1955.
    And yet, God help me, I do love them so!
  6. recardo
    recardo
    from Winslow
    I was reading that Studebaker overproduced everything. They had parts laying around everywhere. It's like they built 1000 widgits if they only needed one. The 59 Lark was made mostly from all the junk laying around. Enough to make 150k of them. Even so, gross profit was less than $200 a car, and net profit was probably $0 :eek:
  7. povertyflats
    povertyflats
    from Missouri
    I don't remember anyone saying they were well built. But some models had alot of style.
  8. Paul
    Paul
    Editor
    ah yes, you bring back all the good memories..
    my '50 had the smoothest collumn shift I had ever driven,
    my '60 had the worst
    but with carefull adjustment it worked nice in my T
    the shifter uses a light weight tube inside the steering collumn,
    the bottom end has a little tab welded to it that controls the levers
    it is prone to wear if not kept greased and adjusted perfect
    it takes some fancy language to get them apart and back together
    you may want to convert to a floor shift.
    that model feels very top heavy, and if it has an anti sway bar in it it's about as big around as a pencil, replacing the front and rear with some nice heavy ones will fix all the wallowing.
    the anti sway bars and some good gas shocks should help the plowing too
    those motors are heavy but they are tough
    unless it has a ton of miles on it just a simple rebuild should make it sing again
    timing gears, rings, bearings and oil pump
    no getting around the fact that you just happen to have the ugliest one ever made though. :D:rolleyes:
    here's my old rust bucket two-door
    oh yeah, mine had been damaged around the bottom of the tail gate and left a gap that let the exhaust inside, just about enough to kill ya..
    and the door latches are the flimsiest stupid design, try finding some that aren't worn completely out..
  9. Hudsonator
    Hudsonator
    from Tennessee
    Yorgi,
    You and I both know, you're spoiled for any other car manufacturer.
    Its kinda like Charlie Sheen once said, "Once you've had Ginger Lynn, you're kinda let down with any other woman."
    Hudson=Ginger
    Hud
  10. RUDOG
    RUDOG
    the Studebaker hub caps are cool....
  11. Have you adjusted the goddamn linkage?haha had to sorry
  12. 29nash
    29nash
    from colorado
    what he said............
  13. Studebaker didn't go out of business. They just stopped making cars. Why? Probably the reasons you stated!!!
    Maybe history is going to repeat itself.
    BTW
    They still exist.
    http://www.studebaker.com/
  14. Dick Dake
    Dick Dake
    Is it the original 50 y.o. suspension? That'll do it. I do agree with you on one thing, 3 on the tree is crap, any make any model.
  15. squirrel
    I thought it was because they were so goddam ugly. they sure didn't have a monopoly on crappy column shifters, lousy handling, etc.
  16. DE SOTO
    DE SOTO
    Sounds like someone just needs a TOYOTA :eek:
  17. Bullet Man
    Bullet Man
    jus t fix the old car. it's still here right? the big three are going out of business also. you wouldn't drive a model t without updating it.
  18. littlejoe631
    littlejoe631
    from new york
    this is a hot rod site modify it it will be fine sub frame newer motor anything you can dream of ????????????????????????????? why not i have seen some nice stupidbakers
  19. 40StudeDude
    40StudeDude
    I don't remember seeing too many stone stock Model T's or Model A's, '32's & up running around on the streets these days trying to keep up with modern traffic...build yourself a modern car...in other words update it...keep the body so it'll look like an orginal...build a hot rod...!!!
    The only thing on my Stude that is stock is the body...
    R-
  20. S1B
    S1B
    What he said!!! MY 53 Chevy and Ford both had shifter problems and handled like a 10ton bricks.
  21. 38plymouth
    38plymouth
    I got a 1946 Vette I'll trade ya even for.....
  22. Skate Fink
    Skate Fink
    Studebaker made some fine cars over the years. They were also very inovative. They just couldn't produce cars in the numbers of the "Big 3" and keep their costs competitive. That's one of the reasons for the wild fins and weird colors. There were things they could do without a lot of retooling.
    We had a 1955 Commander Coupe for 10 years and it was a very dependable vehicle...
  23. I thought that was MOPARs in reverse??
    Oh what a feeling....!
  24. KY Boy
    KY Boy
    If this was craigslist I'd nominate that post for best of. Good rant.
  25. justanotherguy
    justanotherguy
    Hey Yorgie, why are you all pissy? And tell me again why Hudson folded 10 years before Studebaker...
    :rolleyes:
  26. lost_sol
    lost_sol
    from colorado
    I love my stude now that the sbc is under the hood
    Cory
  27. Lstude
    Lstude
    I love my Stude. It shifts just fine!
  28. Nortin
    Nortin
    from Canada
    you shouldn't hold back so much tron, tell us all how you really feel ,, lol
  29. tiresmoke!
    tiresmoke!
    LMAO...go tell Lohnes that. He'll get a kick...and likely agree!
    Hell, it's an old station wagon...unless it's modified, it's GONNA slalom like an elephant on ice skates.
    Column-shift is just one of those things......personally, it's just an excuse to hack a hole in the floor and toss one of George Hurst's beauties on.
    In keeping with the oddball personality of the car, I'd toss a built 401 in it and call it a day...just my lousy$.02
