I finished this T up a few weeks back
Discussion in 'The Hokey Ass Message Board' started by gowjobs, Aug 21, 2004.
  1. gowjobs
    gowjobs
    Took these pics this morning and thought I'd share. Yeah, it's a scale model, but they'd fool a lot of people.
  2. Nick32vic
    Nick32vic
    Holy cow. I think i remember you doing that once before, i you posted a pic and i thought it was real then you said it was a model. Well this time im like "ok self, this may be a model, be on the lookout" so i started looking and im like "damn, its actually real" then i read the bottom. lol
    nice job.
    Nick
  3. famous59
    famous59
    from dallas, tx
    fooled me, good job
  4. InjectorTim
    InjectorTim
    I'm speechless, I thought it was real! You are goooood!
  5. Bitchen!
    The thing that tipped me off is the tires... they stay round where they touch the ground... if you "flattened" them, it would look more realistic...
    But BRAVO on the rest! That must have been a lot of work!
    Can we get a pic of it next to you?? For perspective...
    Sam.
  6. gowjobs
    gowjobs
    Ask, and ye shall receive:
    Well, how bout my ol' pit bull/akita mix instead of my ugly mug?
  7. G Griffin
    G Griffin
  8. Mojo
    Mojo
    Good grief, that's SWEET. Nice stance, great detail. Is that the Lindberg T? Does normal weathering techniques work for 1/8th scale? I've got some ideas for the Big Deuce like that, i'm thinking of starting it soon, and i'd like to waether it a good bit. Very sweet model...
  9. gowjobs
    gowjobs
    Normal weathering works great in 1/8 scale.
    Most of the little rock chips were done by painting my "oxidized steel" mixtures on the part first. I then added moistened salt (table salt for small chips and sea salt for bigger flakes) to the parts and let it dry before painting the piece with the "paint" color. The salt rubs off easily, leaving little pieces of rusty metal showing underneath. For larger peeling paint effects like my brake backing plates, I used rubber cement applied by dabbing with a green kitchen scrub pad, and removed it after the cover layer of paint was dry by tapping it with masking tape to pull it free.
    Washes and dry-brushing work just fine. I actually plan to weather it out a bit more, add a few more wires leading to the lights and starter, and add a coolant-soaked rag tied off around a leaking upper radiator hose, so I'll have to add some spray on the engine and some pools of rusty coolant in the depressions in the intake on that old Y-block.
    To answer the first part of your question:
    Yes, it IS the Lindberg T. I made a mold off the Deuce shell, and cast a couple in resin so I could section this one. In case anybody is interested, I made the weld beads by masking off either side of the weld, leaving less than 1/16" between them, then I applied a tiny little roll of filler to the seam. I used the end of a 3/64" round rod to make the "stack of dimes" look to the bead, then peeled the masking tape away. After the filler cured, a couple of passes with 400 grit took off the high points and paint did the rest of the effect.
  10. Nads
    Nads
    from Hypocrisy
    That's amazing. You are a talented fuck.
  11. DAM...ya had me until Sam pointed out the "over inflated" tires!! [​IMG]
    NICE!! [​IMG]
  12. whodaky
    whodaky
    from Aust
    Nice model Gowjobs. great use of stuff from the old Lindeberg kit and the new issue of the Big Duece. I never really liked the Lindeberg T body. But the style in which you have built your T lends it so well to that body! Geoff aka Whodaky
  13. fab32
    fab32
    FANTASTIC !!!! I want one in 1:1 scale. Thanks for posting it, you could fool just about anyone with those photos.
    Frank
  14. Do those tyres come with the Lindberg kit?! The "finger grips" are a great detail. That thing looks really good. For welds, Have you ever tried "welding" a styrene rod with a Dremel tool into a groove. It gives a great looking bead and even can hold parts together with a bit of practice.
  15. Foul
    Foul
    That's incredible, man. Could you fill us untalented folk in on how to cast resin? I may consider doing that soon for a non-automotive project.
    dan
  16. laverda
    laverda
    Ha! Great job ... until I read the last line I was completely fooled. Keep up the good work.
    Later,
    papa al
  17. Anderson
    Anderson
    Seen it once, love seeing it again. Awesome work!
  18. Had me fooled......man thats fucking brilliant.
  19. The37Kid
    The37Kid
    Nice work! Guess I don't have to warn you about the front brake hoses rubbing on the tie rod afterall.
  20. mikes51
    mikes51
    Great job! That's the most realistic model I've ever seen.
  21. SanDiegoJoe
    SanDiegoJoe
    how does it run in the highway?
    - looks super realistic
  22. gowjobs
    gowjobs
    Smooth-On makes some good stuff for somebody who hasn't done much resin casting, and sells it in kit form (resin and hardener) in several different quantities. The resin is cheap - it's the silicon to make the molds that's expensive.
    Last year, Fine Scale Modeller or Scale Auto magazine (both from Kalmbach Publishing) had a really good article that showed prepping the item to be molded and the process of making a multi-part mold in a step-by-step format. One of the ideas that I liked was the use of Legos to make a box to contain the silicon mold. The mold-making process is much more involved than the resin-pouring process.
    To help eliminate bubbles in the resin as it hardens, it will help if you have access to a vacuum chamber to help the air escape from the mixed resin. Whether or not you can vacuum the wet resin mixture before you pour it, it'll also help to eliminate bubbles and voids if you can fill the mold (actually, over-fill it a little to make sure the mold is completely full) and then place it in a pressurized chamber while it cures. A painter's pot hooked up to your air compressor with a pressure gauge and ball-valve to regulate it will go a long way if the mold is small enough to fit in there. Experiment with pressure. Some molds like more (up to 80psi) and some only need 20psi or so.
    Hope this gives you a few ideas. I have a buddy who casts and sells model car bodies as a side-business. He's been kicking around the idea of holding a three-day seminar on how to cast in resin - he figures it'd take that long to make sure every participant has a chance to perform the whole process, from start to finish and learn all the tricks he's come up with in the last fifteen years of doing this stuff.
    The wheels, tires, salt-flat discs, indian blanket and most of the rear suspension came out of the Revell-Monogram 1/8 "Big Deuce" kit just recently re-issued. The deuce is my next project... a deep channel, flathead powered with magnesium Americans and white wall slicks. I'm thinking that one will be lime gold metalflake.
    Dave
  23. bigron
    bigron
    that's pretty neat!
  24. Winfab
    Winfab
    Your model is so realistic I was fooled. Great job!
    I haven't built a model, with the exception of helping my son, for almost 40 years. I still have quite a few of my models including the Monogram "Big T" that I built back when I was about 13 or 14. I've always thought it would be fun to rebuild it. Some of the parts are falling apart. Any suggestions for an old novice that would help with disassembly to some extent to enable a rebuild?
    Thanks for posting your pictures.
  25. deuceguy
    deuceguy
    Ya had me too! Very nice.
  26. FoMoCo_MoFo
    FoMoCo_MoFo
  27. You are SICK! [​IMG]
  28. stan292
    stan292
    Damn nice! I gotta admit, you faked me out bigtime.
    I've done a good bit of modeling (although it's been several years back), and this is the first time ever that I recall being totally fooled. Even looking back through the shots after you "fessed up", it was hard to convince myself it wasn't real.
    Great fun, and very cool. Thanks for sharing.
    P.S. You must have some other neat stuff. How about showing it too?
  29. Antibilly
    Antibilly
    thats fucking on hit man......IM FOOLED BIG TIME!!! hahahah
    wanta sell it? [​IMG]
  30. Beautiful model, man! I love it.
    You're one hell of a modeler. Like the others, I thought..."Well, he finally got a project car done."...Lo and behold...........Sweet!
    Joel [​IMG]
