I give up!!
Discussion in 'The Hokey Ass Message Board' started by glmke, Jan 28, 2008.
  1. glmke
    glmke
    Ok I tried to wire the hotrod and i give up.I know my limitations so does anybody know a wire guy in the portland oregon area.Maybe someone who does mobile service. let me know thanks
  2. snapper
    snapper
    from PNW
  3. SlamCouver
    SlamCouver
    from Brazil, IL
    what are you wiring?
  4. Wiring is just like plumbing, you run a wire from point A to point B. It's easy. What are you having trouble with? The biggest problem people have is with grounds. Everything needs to be grounded. Get a book like Snapper says. For something to work, you need a hot, a ground, and a switch. Make sure you put everything on a fuse too. Dean (ps) I sent you a pm with a phone #
  5. SlmLrd
    SlmLrd
    from DAGO
    Great book. It will save you some headache, but there are a few things in the book that were backwards for my last car I wired with a 302. Either way- please, NEVER give up. Go in the house and relax. Come back out with a fresh mindset and finish her up. I can wire practically anything, but when it comes to metalwork.... Gah! :eek:
    Live and learn, thats what we do!
  6. glenn33
    glenn33
    from Browns, IL
    Don't give up...PM me. Between Bob an I maybe we can figure out what's wrong.
    Glenn
  7. If you're wiring a simple car like the pickup in your avatar, you're only dealing with four systems.
    Ignition
    Start
    Charge
    Lights
    Granted, lights are the most complex, but once you've done the preceding ones - and tested them as you went to make sure they work - a few extra wires for lights is no big deal.
    Electricity is like fluid in a pipe.
    You were able to plumb the car for fuel and brakes were you not?
    Your mind is a funny thing, keep telling it you can't do something and it won't be long until you won't be able to do it.
    Best part about wiring your car yourself is you'll be able to trouble shoot problems on the road.
  8. Old Rod
    Old Rod
    from Brazil, IN
    Good info C9 as always. That book is also helpful. I had a friend draw a schematic
    and I followed it. If I can do it anyone can, really dumb about electrical stuff.
    Don't give up. Think how good you will feel when you figure it out!
  9. Petejoe
    Petejoe
    from Zoar, Ohio
    Just like the guys mentioned above. Don't give up.
    We love the challenges! :)
    We can help you step by step through this.
    But first tell us what kind of vehcile and whether you are using a harness kit....
    Once you get it done you'll be a wiring fool.
  10. Dirty2
    Dirty2
    Never give up ....
  11. spudsmania9
    spudsmania9
    from Arkansas
    Have you looked at the Painless (TM) kits? I used one in my OT 1966 F100. I like the way every wire is labeled and the full instructions help a lot.
    Not running down any other kit, this is just one that worked for me.
  12. willys33
    willys33
    from New Mexico
    Don't look at the entire job all at once. Do one wire at a time and finish one before moving on to the next. Use bread ties to keep the wires in place temporally as you go. After completion, replace the bread ties with regular nylon ties and cover with a split protector. Test each circuit as you complete it.
  13. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Don't go and do that. Post your questions on the forum, everyone can help and Im sure it can get figured out. Wiring isnt that scary. I cant wait to get done with this sheetmetal bullshit on my Merc to get to wiring actually. Pair o' wiring pliers, some connectors, and you dont even have to get dirty or have loud tools going, but Im kinda a girly car guy I guess.
    Seriously, if it is the thing in your avatar, post your problem areas in a thread, everyone is here to help.
  14. llonning
    llonning
    Willys33 probably said it best. One wire at a time. If you think that you have problems, try doing wiring being color blind!!!!! If I look at a wiring job in total 2 things happen. I get perplexed then I get totally pissed!!!!!!! I have wired a lot of turcks and trailers and found that Willys33 is correct. ONE at a time it works the best.
    Good luck and good rodding!!!!!!!
  15. butch27
    butch27
    Yeh: That book had some Ford Start Relays labeled backwards ( they are directional).
  16. SlamCouver
    SlamCouver
    from Brazil, IL
    Forget books or online articles! How bout some hometown heros:D? Im right across the river from you, if you need a hand this weekend Iv got a buddy that is my wiring goto guy. I can get him to come over there with me.
  17. Fairlane Dave
    Fairlane Dave
    Hang in there and don't give up! I had never worked on anything electrical in a car before and finished my complete rewire on my SBF/Fairlane a couple of months ago. I got very frustrated a few times along the way, especially after reading how some folks can do the whole job in a day or two. It took me 4 or 5 weekends, but I was determined to finish it myself. Between this forum and the folks at Rebel Wire, I got through the issues and feel pretty damned good about finishing the job.
    I'm assuming you have a Rebel kit since Glen posted on this thread. Those guys are serious when they say to call or email any time. I had them on the phone with me while I was in the garage working out my turn signal problems. They had me pointed in the right direction in no time.
    When I start my '54 truck build, I will surely get it done a lot faster having finished this one on my own.
  18. glmke
    glmke
    ok here is what i have. 6 volt batt. pos. ground. have key switch that turns starter but will not start car. have to push solenoid to start car.new head lights tail lights.
    solenoid
    key switch
  19. rustyford40
    rustyford40
    from Mass Bay
    My first queston is why are you staying with 6v.
  20. glmke
    glmke
    tell you the truth truck came with 6 volt and do to my budget decided to stay with it.
  21. rustyford40
    rustyford40
    from Mass Bay
    Your best bet is to go with a Painless kit. All the wires are labled on the wires. The book will walk you through it real easey to do. It's the only way to go.
  22. llonning
    llonning
    Which solenoid is that??? It has been about 30 years ago but my grandfather had a machine (Had a weird name for it and I still have it), that used a solenoid with a button on it. It would not work with a key start, you HAD to push the button. The small terminal was for the charging system. It needed a complete rewire to start with a key. Also yes it was 6 volt at the time and positive ground. We finally switched it to 12 volt and did the rewire.
    Good luck and good rodding!!!!!!!!
  23. glmke
    glmke
    okay i looked at painless wire kit and looks like a basic 8 circuit will cast about 330$. wow is that what i'm looking at as far as cost to wire my hot rod?
  24. rodknocker
    rodknocker
    No, go back and get more pics of where the wires lead off of the solenoid and post them.Is the problem just with starting it or are there other issues?
  25. glmke
    glmke
    yes just starting the truck, turn key and starter turns but slow. turn key to power and push solenoid truck will start
  26. rodknocker
    rodknocker
    What I would do first is bench test your components.You'll need a multimeter set on ohms.You want to check for continuity through all of the positions of the ignition switch.This is done by finding your ground,hooking up the black lead of the multimeter to it,then hook the red lead up to the acc.,turn the key to acc, and you should have continuity,do this for all positions of the switch.This will verify it is a good switch.Now for your solenoid,remember it is just a big relay,it uses little power to turn on big power, meaning it gets a signal from the ignition switch through the small wires to connect the power internally for the big wires,thus hopefully turning the engine over.While all of this is happening, your distributor has to have constant power.If you have it the wires on the distributor wired up to a circuit that cancels out when the starter is spinning, the truck will never start because there will be no spark from the ignition.I hope this makes sense and helps a little.
  27. rodknocker
    rodknocker
    I think you may have your distributor wired to a circuit that cancels when the ignition switch is in the start position.Verify you have power at the distibutor when it is cranking.
  28. rodknocker
    rodknocker
    Or if you want to make it simple get a start button and wire it to the solenoid directly and keep it the way it is, like the old roadsters.
  29. glmke
    glmke
    okay will try, thanks for info.was thinking of a start button. how would i wire that up
  30. rodknocker
    rodknocker
    You would need the wire that activates the solenoid(small one).I would run it though your ignition switch, then in series to the solenoid.Hope this helps.To verify that this would work and there isn't anything else going on,Take a jumper cable from the small wire on the solenoid to the negative on the battery, this should turn it over just like pressing the button.I say negative because you said it was a positive ground.
