it would be easier to fix the problem rather then spending the time rewiring a start ****on........i think i read that wrong you are using the ****on to help you diagnose the problem right?
tried the jumper.solenoid did alot of clicking and motor barely turned over.when i push ****on on bottom of solenoid the moter turns smooth and starts right up.
take a jumper wire straight from battery to your ****on then from the botton to the solenoid. maybe the wire from you ignition switch is losing some voltage or something. does it crank slow still?
hell just nevermind the ****on hook the wire straight from the battery to the small wire on the solenoid....what happens then?
something inside the solenoid isn't strong enough to make the conection, but when you force it by pushing the ****on on the noid it works properly. is it fo sho a 6 volt noid?
just to be sure hook a grond wire from the metal piece with the two mounting bolts in it straight to the ground on the battery then try the hot jumper again
the part of the solenoid that mounts to the fender or where ever its mounted to. the shiny piece that the 2 bolts are going through, make sure its grounded good, ground it straight to the battery, there maybe to much paint behind it or the fender may not be grounded good enough.
run a wire from the ground post on the battery to the top part of the solenoid the same shiny piece of metal that the 2 mounting bolts go through, that part of the solenoid needs to be grounded
use some jumper cables and just clamp it on there, or a piece of wire with alligator clips on it.....you see what i'm sayin?
I am sorry I don't mean to interrupt it sounds like You guys are on the right track but I was wondering what dose the purple wire off the back of the ignition switch hook to because it looks like it is connected to the same pole as the start pole I might be wrong but it is hard to see by the pic.
I agree with these guys that the silonoid needs to be grounded. Or mabe the silonoid is 12 volt and 6 volt is not enough power to work the silonoid. I just wanted to add that I got my ez wire kit for 89$ and it worked great in my coupe. click on my signature model a build I have some pics of my install that might help. you can run 12 volt batt and put in a 6 volt voltage regulater for about 12$ from speedway
I got mine brand new on ebay for $125 so if I were you Id look on ebay for a brand new painless kit or ezwiring kit. Unless you already have it all down without the kit. -Jon
just got home from work with 4 hours of ot i'm zapped. Will work later on it, will keep you all posted.
Ok i ran the wire from ground post to the top of solenoid. first, what is suppose to happen and second how do i know if is grounded. thank you all for your help. i'll get this or die trying
all right now that its grounded, hook your hot wire from the battery positive post the the small poll on the soleniod. does it still turn over ****y or does it start?
