I hate fabricating brake lines
Discussion in 'The Hokey Ass Message Board' started by Dane, Mar 29, 2013.
  1. Remember that one bender usually can not do all you need. I have a nice Rigid andone of those circular 3 in one benders and a couple I forget. I also made a jig to bend 3/16 lines real tight close to the flare nut for weird tight bends that nothing else will do.
  2. bgaro
    bgaro
    i don't mind it so much, it takes patience, and doesn't always come out the first time. it's to easy for me now, so next build is mechanical brakes. that should piss me off properly.
  3. fsae0607
    fsae0607
    Lots of trial & error, my friend.
    Using coat hangers/welding rod for mockup really helps, too.
    Best money I've spent was on the Eastwood flaring tool. No leaks and I've made quite a few brake and fuel lines on my 61.
  4. ZZ-IRON
    ZZ-IRON
    from Minnesota
    I hear you
    did some lines on my 61 Catalina ragtop up front
    with the motor in place bent them to fit they looked close
    they were not pretty just want the bakes to work
    but this simple task turnout to look like a mess weaving around
    everything - next time i try this i'll remove the obstacles
  5. langy
    langy
    I find most of the benders are too big a radius so I spin up small diameter bungs and machine a deep 3/16" groove in them, then i just bend the brake line around the small diameter, works great and you get nice tight curves.
  6. woodiewagon46
    woodiewagon46
    from New York
    I made up sets of 90 and 45 degree bend templates for 3/16", 1/4", and 3/8" tubing. First I rolled a tubing cutter around the tube where it lines up with the bend mark on the tubing bender just to score the tube, don't cut the tube, this is just the line up mark.Then cut up 3" sections and make your sample bends. I keep the templates in my tool box and when ever I need to make an exact bend I just align the score mark to where I need the bend and mark it on the new tube with a sharpie and make the bend, it makes perfect bends every time. Also I found out the hard way that it is NOT recommended to use a tubing cutter to cut stainless steel tubing. The wheels on the tubing cutter "work harden" the tubing and it will crack, use a fine and new hacksaw blade and it works great!
  7. The37Kid
    The37Kid
    Welcome to the HAMB woodiewagon46! Thanks for the stainless cutting tip. Bob
  8. Dane
    Dane
    from Soquel, CA
    Good stuff guys - Thanks!
  9. BillyM
    BillyM
    The one's that I finally "nail" are usually the one's that I forget to put the flare nut on!
    Then again, that's all practice too!
  10. tommy
    tommy
    My favorite bender. I clamp the non-movable arm in the vise and then you are able to copy a damaged piece very close. A sharpie lets you mark the center of the bend and all you need to do is rotate the old tubing until the new bend is level and then bend to match.
    I've replaced an *** load of brake lines in my brake shop with only the cheap red plastic kits sold at all the tool suppliers. You can buy some fancy expensive benders and flaring tools but it's really not necessary. others may disagree. The mini cutter is handy too. Don't get all hung up on a crooked flare. The flare nut pinches the flare against the fitting. It will seal just fine when tightened up.
    I really enjoy it.
  11. Provience
    Provience
    So that they may become Art to show others how it is done!
  12. Drewski
    Drewski
    For bending the lines I was pleasantly surprised at how well the HF brake line pliers work. I did have to take a round file and clean up the rough areas inside the jaws of the pliers, otherwise they did a good job for me for around 10 bucks.
  13. Tnomoldw
    Tnomoldw
    HMM!:confused:
  14. Deuce Roadster
    Deuce Roadster
    I exclusively use Imperial tubing benders ...
    But you need a different one for each size. 1/4, 5/16, 3/8 and 1/2 :(
    But they work exceptionally well.
    And I use a 71475 Mastercool flaring tool.
    Here is a YOUTUBE video of the Mastcool flaring tool being used.
    http://www.youtube.com/watch?v=fJJKA_Gm9Ks
    Good tools DO NOT cost money ... they save you time and money :D
  15. thedrick
    thedrick
    from latrobe pa
    Call inline tube. They show up in a box all done. After you get the bends all pretty and then screw up the flange. That's the easy way
  16. Just bought one of THESE, 100% perfect flair every time. Love it.
  17. 63comet
    63comet
    I just used a tool like above for my lines and it was much easier to use than I expected from a ten buck Azone tool. Having a vise handy would have really simplified things. I used pre-flared lines as I'm still nervous about doing that myself.
  18. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    Also keep in mind that one day when the car is finished and together you may have to get to a line to fix it, or get it out to replace it. . . so don't make some overly complicated brake line that's not serviceable.
  19. heatnbeat
    heatnbeat
    from Madera,Ca.
    This is exactly the same way I do it! Works GREAT!:D
  20. Marcosmadness
    Marcosmadness
    Lots of good advice. One more idea that I think is worth mentioning. Make the longest brake line first... This is usually the line from the master cylinder to the rear of the car. And then make the next longest. If you screw up a long line you can still cut it into smaller lengths to make some of the shorter lines. If you make the shorter lines first and you screw them up, well, then it is time to buy more line. Someone mentioned using cunifer brake line which I find is a lot easier to work with than the traditional steel brake lines. Plus the cunifer brake lines don't rust over time.
